Car is knocking and stalling out in neutral
Old Apr 16, 2006 | 10:07 AM
z3gsr's Avatar
z3gsr
Default Car is knocking and stalling out in neutral
Hey everyone.. This question is for all of the teg owners. Last night I was following my friends m3 to his house. I shift around 7 rpm from 3rd to 4th and on the 4th gear somthing happend. When I put it on 4th the car redlined and the whole car shooked. My car was idealing really hard now and Theres a knock in the engine. When I was driving home my GSR stalls on neutral. Can anyone of you guys help dignoste my problem. Thanks
Old Apr 16, 2006 | 10:14 AM
VPUPPY's Avatar
VPUPPY
Sounds like you over revved your motor. You might have bent valves. You need to get a compression test to verify this.
Old Apr 16, 2006 | 10:42 AM
g290ls's Avatar
g290ls
they call me tater salad
that sounds bad bro...i would get it checked out asap
Old Apr 16, 2006 | 10:45 AM
z3gsr's Avatar
z3gsr
So its the valves
Old Apr 16, 2006 | 10:58 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
You may have floated a valve, cracked your head or possibly seized a piston. The only way to full know would be to have a leak down test performed or tear the motor apart. Why are you shifting so high anyways? To keep up w/an M3? Bad idea...IMO.
Old Apr 16, 2006 | 11:14 AM
z3gsr's Avatar
z3gsr
Yea I know its a bad Idea. I didn't think anything of it. I use to race alot and I always power clutched. I always tought that the govener kicks in when a cars about to redline.
Old Apr 16, 2006 | 11:34 AM
ewood87's Avatar
ewood87
Eric Wood
go buy a geo metro
Old Apr 16, 2006 | 11:46 AM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Yeah but you have to think of it this way, the governor is there to cut you off in case you accidentally over-rev the engine. So you don't blow it up. It does not reduce the stress on your engine until that point. It just prevents the over stress. Once you've stressed it out enough, you fall into the heap you are in now.
Old Apr 16, 2006 | 01:30 PM
z3gsr's Avatar
z3gsr
Thanks guys for the info. I can't belived this really happend I always shift high to get into v-tec and know alot of people who shift close to redline and never effect thier car. I was wondering do we have to drop the block to replace the valves? I was reading this link
http://www.c-speedracing.com/howto/v...alveadjust.php .
I was also wondering how much this is going to run to fix at the shop.
Old Apr 16, 2006 | 03:42 PM
VPUPPY's Avatar
VPUPPY
Drop the block to replace the valves?? You don't need to remove the block, just remove the head to fix the valves if they are damaged. Did you do a compression test or leak down test yet? I would do that first before you go all out and tear the engine apart.
