eagle manifold and vac lines
Old Apr 11, 2006 | 04:27 AM
rugsr's Avatar
rugsr
How do my taillights look
Default eagle manifold and vac lines
anyone here have a pic of there eagle manifold with vac lines veiwable for me......im installing it soon and need to know where the vac lines go and come from. anyone, thanks!
Old Apr 11, 2006 | 05:43 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Golden Eagle?
Old Apr 11, 2006 | 07:10 AM
rugsr's Avatar
rugsr
ye sorry
Old Apr 11, 2006 | 08:08 PM
KaBlookie's Avatar
KaBlookie
4-doors ROCK
got this from Golden Eagle's website:
http://www.goldeneaglemfg.com/images..._SCHEMATIC.pdf
that's not the only way to do it, but it's certainly a do-able option
Old Apr 11, 2006 | 09:46 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Here is how I have mine hooked up:
I suck at paint, but everyone keeps asking for it, so this will save some explaining.
File Type: jpg
Old Apr 12, 2006 | 04:50 AM
rugsr's Avatar
rugsr
BOV comes from BOV
3.5lb MAP.....if im running stock then i wont need this right
Boost gauge comes from gauge-where did u get that adapter for the little line to go into the bigger hose?
EBC controller is the Electronic boost controller? can i use the manual one u sold me right here?
WG is the wastegate and that come from the one on the side, not the top right?
THANKS BTW, both pictures are big helps
Old Apr 12, 2006 | 08:55 AM
Provocateur
On permanent hiatus
Originally Posted by rugsr
BOV comes from BOV
You won't need the EBC controller or the 3.5 bar MAP sensor. The manual boost controller I sold you splices halfway into the wastegate line.
I got the adapter for the boost gauge fitting at Pepboys.
Old Apr 20, 2006 | 05:59 PM
rugsr's Avatar
rugsr
on the tial 38mm WG there are 2 ports a back and a top....i use the back right?
on the inlet side of the turbo theres a brass elbow fitting....does something go there?
Old Apr 20, 2006 | 06:28 PM
Provocateur
On permanent hiatus
The inlet side of the turbo is where you want to connect the wastegate because it is will see boost as it is being made instead of waiting for it to go through all the piping and to the vacuum manifold. You don't have to tap it here, so if you want to use the manifold, plug it with a vacuum cap.
Old Apr 20, 2006 | 09:33 PM
rugsr's Avatar
rugsr
so let me get this straight.......
connect the back of the WG the fitting on the inlet of the turbo? does the boost controller u sold me go in between there and tee off to the VAC Manifold....
