eagle manifold and vac lines
Old Apr 22, 2006 | 06:47 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
I didn't have a fitting on the compressor housing at all.
Old Apr 22, 2006 | 11:58 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by rugsr
u left the fitting open?
would you loose boost from there?
Not all turbos come with a nipple on the compressor housing.
Old Apr 23, 2006 | 09:12 PM
rugsr's Avatar
rugsr
How do my taillights look
but if there is one....which there is one on mine i should cap it then right?
looking at that pic again from the link provided i understand how to hook it up now BUT it says to put it back into the intake manifold b4 the throttle plate....i thought it should be run to my vacume manifold.....or can it?
Old Apr 23, 2006 | 10:04 PM
Provocateur
On permanent hiatus
I wouldn't cap it. It will give you the best wastegate response if you tap the source from there since you will be seeing it as it is made. I wouldn't run it to the manifold.
Old Apr 24, 2006 | 07:55 PM
rugsr's Avatar
rugsr
wow im usually good at seeing this in my head but for some DAMN reason i cant get this: let me try 1 more time:
Old Apr 24, 2006 | 10:02 PM
Provocateur
On permanent hiatus
Still wrong.
Tell me what ports on the wastegate are supposed to go where and I will draw something up for you.
Old Apr 25, 2006 | 04:58 AM
rugsr's Avatar
rugsr
DAMN IT!!!!!!!!!
ok here it is:
Port for the BOV, port on the cold side of the turbo, 2 ports on the WG(top and back), and that manual boost controller. I dont care where they go as long as its right and will make the car start!!!! hah this is killing me, and i know once i see it ill be like AAAAAAAHHHH ok ok i get it
Old Apr 25, 2006 | 08:55 AM
Provocateur
On permanent hiatus
What do the two ports on the wastegate do? You are making this a whole lot more difficult than it should be.
Old Apr 25, 2006 | 09:08 AM
rugsr's Avatar
rugsr
lol i know!
im not sure the the 2 ports do but i do see a lot of people not using the top port.
i was told to just connect the compressor side nipple to the back port on the WG and not use a BC. just run it off the spring
