heating problem
Old Mar 22, 2006 | 05:12 PM
christheape's Avatar
christheape
Default heating problem
The question is my temp goes up when in traffic. When I go it starts going down a litle or when I turn the ac on low it seems to help. So when i got home I let it sit for awhile. Then check the fluid it's just fine then started the car and just let it run. It got hot after about five min. It got up to about half way. so I turned on my a/c itr made both fans come on so I checked the fuses for the cooling fan and relay there fine. Has any one else had this problem ? And how do you fix it?
Old Mar 22, 2006 | 06:46 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
AC wont make it cool down...turn on the HEAT..if it blows cold air than you prolly need a new thermostat.
Old Mar 22, 2006 | 07:25 PM
christheape
when you turn the ac on it turns both fans on
Old Mar 22, 2006 | 07:26 PM
christheape
so i need to figer out how & why my single fan isnt turning on when it gets hot
Old Mar 23, 2006 | 07:29 AM
flybye's Avatar
flybye
could be a fan switch.
Old Mar 23, 2006 | 10:01 AM
R_Squared's Avatar
R_Squared
LEVEL UP
where is that btw? I need to check mine out since my fans aren't kicking on.
Old Mar 23, 2006 | 10:17 AM
crzy000's Avatar
crzy000
depends what kind car you have. the wire that goes to the primary fans is under the intake manifold. it's hooked up on the block, you can also by pass that and have it turn on when the ignition is on. that's what I did to mind becuase my switch sensor is bad. 89 crx
Old Mar 23, 2006 | 04:42 PM
christheape
well how do i do that ,or can iI just splice a switch in where the swensor is in the block Or tap in to the wires at the fan?
