what do u guys think of this
Originally Posted by tegbooster
^^ there was 22 smileys... dont forget the final one at the bottom
Originally Posted by kiddcarbuff
wht do you think about this....http://cgi.ebay.com/ebaymotors/OBD1-...27639594QQrdZ1
The bigger point in all of this is that a generic chipped ECU isn't the ideal solution. A user-programmable ECU, such as the AEM EMS, the GReddy E-Manage or the Hondata range are more flexible in the long run.
Lastly, if alll you've got is the standard intake, header and cat-back, you're well within the range of the factory ECU's fuel map. You're better off IMO adjusting ignition timing than you are dropping $200+ on some mystery ECU.
Originally Posted by SP00NFed
don't buy what you don't need. your stock ecu is great until you start getting certain parts then you should worry about getting your ecu chipped and tuned
Originally Posted by TheOtherDave™
Torn_Phoenix and 97civicEXVTEC:
There are productive ways of answering the OP's question, without being sarcastic or demeaning. Using 21 smileys in a single post is not one of them. :squint:
Originally Posted by red94teg
i want to put the stock ECU back in my car but I'm afraid cause the previous owner disconnected so many sensors and shit, my teg will probably run like ass! :noes:
