hoe much boost can you run on stock type r?
Old 01-07-2006, 07:19 PM
itrdc2
itrdc2's Avatar
Default hoe much boost can you run on stock type r?
i just got in my turbo its a drag kit and was wondering how much boost these itr's can handle. can they handle 10psi daily driven likes gsr's on stock motor?
Old 01-08-2006, 12:43 PM
97civicEXVTEC
97civicEXVTEC's Avatar
what turbo are you running? the compression on your motor is really high so i wouldnt recomend anything over 7.
Old 01-08-2006, 03:42 PM
nsxtasy
nsxtasy's Avatar
None. If you run boost, it's not a stock Type R.
Old 01-08-2006, 04:36 PM
Provocateur
On permanent hiatus
Provocateur's Avatar
Psi doesn't mean shit. CFM does.
I wouldn't push more than 300 whp out of any stock B-series motor.
But to answer your question, if you have good tuning (not the halfassed tuning method Drag provides with the kit), 10 psi wouldn't be a problem on a stock block B18C5.
Old 01-08-2006, 09:09 PM
itrdc2
itrdc2's Avatar
i was planning to go with a drag kit since i want to keep all the ac and ps. but i might change the manifold and get a rull race ac on.
Old 01-08-2006, 09:11 PM
itrdc2
itrdc2's Avatar
i guess for now i was just gonna use the fmu untill i can get some type of mangement. do you tink i would be able to run 10 psi on a track day or maybe even daily driven? not like im going to be boosting at all times
Old 01-11-2006, 09:49 AM
Provocateur
On permanent hiatus
No. Don't half ass the most important part of the turbo system; especially with a high compression motor. If you care about your reliability, do it right and get either a standalone or a chipped ECU to handle fueling and ignition.
Old 01-12-2006, 10:36 AM
typer_696
typer_696's Avatar
some places wont recommend more than 5 psi due to the compression. Dont do it half-assed and get it done right
Old 01-12-2006, 06:28 PM
g2_teg_na
^ Visual Learner
g2_teg_na's Avatar
i'll bet 10 psi added to a stock type r with a t3 would be more than 300 hp for a stock b series block. i saw 8 psi make 294hp. i dont know the size of the turbo, but i doubt it was much bigger.
you say 10 psi wouldnt be a problem. is that 10 psi on a t25, t3, t66? thats something that needs to be specified...
Old 01-12-2006, 07:21 PM
Provocateur
On permanent hiatus
Read his first post. He states that this is with the Drag kit.
I highly doubt the engine would make that kind of power from a basic Drag kit on a high compression motor like the Type R because the ignition would have to be pulled a good amount to avoid detonation on pump gas.
