my car just dies....
Old Sep 11, 2002 | 04:28 PM
joebenz's Avatar
joebenz
nelson rules
Default my car just dies....
i dont know what the heck is goin on here... ok, here it is... when i first start my car, it is running fine, but then after i drive it, and then have to come to a complete stop, my car will just die. it only does this once and a while, but today, it did it everytime i stopped. it does it both when i keep the car in gear and push in the clutch and when i just put the car in neutral. any idea what the problem could be, and how i can fix it? thanks a lot
no sig
Old Sep 11, 2002 | 06:22 PM
ant6177's Avatar
ant6177
Go to your nearest auto parts store and get your electrical system diagnosed. Most places will do it for free, you may need to replace your battery or perhaps get it recharged. If not it sounds like your alternator replaced. How's your car's idle doing?
Old Sep 11, 2002 | 06:45 PM
joebenz's Avatar
joebenz
nelson rules
the idle when it started doing this is lower than it used to be
no sig
Old Sep 11, 2002 | 07:00 PM
DB7 2.0's Avatar
DB7 2.0
Banned
has the car ever "sputter" or "hiccup" when driving it like on the street or freeway?
hows your sparkplugs? how many miles do you have on that fuel filter (although you do have a relatively new car)? is your airfilter clean?
Old Sep 11, 2002 | 07:53 PM
joebenz's Avatar
joebenz
nelson rules
nope, it never sputters or hiccups.
i have 34k on my car...not sure how much on the fuel filter. ...and yeah, my air filter is clean
no sig
Old Sep 11, 2002 | 08:21 PM
DB7 2.0's Avatar
DB7 2.0
Banned
check ur ignition..... see what your plugs look like...and no not ur butt plug! :fawk: h:
Old Sep 11, 2002 | 08:32 PM
dubcac's Avatar
dubcac
I
Yeah check for spark.
Old Sep 11, 2002 | 08:43 PM
woong's Avatar
woong
wouldnt happen to have just gotten a valve adjustment would u?
Old Sep 12, 2002 | 03:33 AM
madlow's Avatar
madlow
If you haven't done it since you've had the car it's time to change your plugs, wires, cap, and rotor.. That may be the problem.
I know my civic did this at one point and changing everything above fixed it. It use to come to a real low idle when I came to a stop and stall.
Old Sep 12, 2002 | 04:43 AM
Aschlegel1's Avatar
Aschlegel1
WOW O&A Cum Back!
