installing a vtec head on a 90 rs teg
Old Nov 16, 2005 | 02:52 PM
Originally Posted by [Damnit]
well because the LS pistons aren't built for that high RPMS
what pistons the guy has is not related to what his peak rpm will be...the weak point of the ls lower end with a gsr top end is the rod bolts....not the pistons...he could if he wanted use those ls pistons on a car that has upgraded valvetrain and rod bolts on a motor runnin 10000 rpms if he wanted
Old Nov 16, 2005 | 03:07 PM
tegbooster's Avatar
tegbooster
Resident Ninja-photo'er
i was in the process of doing a ls/v swap and eventually changed my mind to go w/ boost...i suggest you do lots of research on several things
a) power gains w/ both builds
b) min and max costs of both builds
c) reliability
i did about 4 months of research on all of those topics and i decided to boost for several reasons...if u think ur ready for the full ls/v though....have another 500-1000 ready in the bank for when u realize u need something else....or stupid shit like that...definately can cost ya
hope this helps
Old Nov 16, 2005 | 03:18 PM
IntegraType-R's Avatar
IntegraType-R
ALL MOTOR KING
Originally Posted by teg92
Ls vtec wouldnt be realiable unless if the bottom end was built.
http://www.c-speedracing.com/howto/lsvtec/lsvtec.php
heres a write up on it Good Luck!
the most retarded thing i've heard in such a long time..
LS/VTEC is as realiable as the next hybrid motor, if put together correct, granted if u have a 150,xxx mile ls motor i'd suggest in replacing the usually, gaskets, rings and rod bolts, possible some seals and what not.. but other then that.. your fine, ls/vtec in short is almost a bolt up situation, grab a ls/vtec kit from golden eagle and go from there.. its usually a weekend put together but it takes time, specs have to be made, and yes you need to get a vtec ecu..in short, ls/vtec will probably yeild you using all stock parts around 180is'-190ish wheel hp, i've seen some stock ls/vtec's go good for 14.3's at the track..pretty quick, i'm sure with some i/h/e mods and some cams u could break 13's easily..thats my input, being i've built like 6 of em, not like i know anything..tho.
Old Nov 16, 2005 | 05:15 PM
teg92's Avatar
teg92
WHAT OK YEAH!
im not the only one that says you need to build the bottom end. Out of the 6 you put together how many of them are still running?
Old Nov 16, 2005 | 08:00 PM
dubcac's Avatar
dubcac
I
YOU DON'T NEED A FULLY BUILT BOTTOM END FOR 8000 RPM. Just rod bolts. Shit, I've even seen BONE STOCK LS and B20 bottom ends hold up to 8200rpm and 12psi...but I wouldn't risk it.
Old Nov 16, 2005 | 09:44 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
:werd:
ARP Rod bolts are cheap insurance against something catastrophic like a spun rod bearing.
Can you rev up to 8k+ on a stock LS block? Yes.
Will it last very long without proper reinforcements? No.
