my compression test #s
Old Sep 9, 2002 | 10:14 AM
gsrstyle's Avatar
gsrstyle
Nitrous Junkie
Default my compression test #s
starting from RIGHT to LEFT ; 115 , 115 , 115 , 105.
i have a b18c1 with 55k miles, everyone in autoshop said my numbers were really good but i thought they were kinda low..
Old Sep 9, 2002 | 10:17 AM
reno96teg's Avatar
holy sh*t that's low. are you sure they didn't screw up? i'd get another test done. for that milage, that's horribly low.
Old Sep 9, 2002 | 10:20 AM
gsrstyle's Avatar
gsrstyle
Nitrous Junkie
ya i followed the directions on c-speedracing so hopefully i did eveything right!
Old Sep 9, 2002 | 10:47 AM
reno96teg's Avatar
was the engine warm? did you pull all of the plugs out? did you let her crank enough times over?
Old Sep 9, 2002 | 11:11 AM
gsrstyle's Avatar
gsrstyle
Nitrous Junkie
the engine was cold and we only pulled out 1 plug at time.. maybe that was a problem?
Old Sep 9, 2002 | 11:13 AM
Etylorcen's Avatar
Etylorcen
Turbo Mafia Soldier
Hehe yeah that could be a problem.
Old Sep 9, 2002 | 11:46 AM
reno96teg's Avatar
could be. make sure the engine is at operating temperature and that you have all the plugs pulled. you should get higher numbers. also, let her crank several times for each cylinder to get the max. reading. looks like one of your cylinders is going to be down a bit, which probably means a worn exhaust lobe or similar. if it's within spec (like max of 10-15% difference from the others), you're still ok.
let us know what you get.
Old Sep 9, 2002 | 11:50 AM
reno96teg's Avatar
one more thing, make sure you have the gas pedal pressed all the way down.
i'm surprised c-speedracing didn't mention anything about doing it at operating temp.
Old Sep 9, 2002 | 07:42 PM
gsrstyle's Avatar
gsrstyle
Nitrous Junkie
will try again =)
Old Sep 9, 2002 | 09:40 PM
dubcac's Avatar
dubcac
I
Yes make sure you are at WOT, all plugs and ecu fuse out.
R_Squared
4
Dec 28, 2005 05:14 PM
