motor oil as transmission fluid??
Old Sep 13, 2005 | 05:04 PM
qtiger's Avatar
qtiger
Originally Posted by 94JR
Motor oil can lubricate the motor so it can do the same for the transmissoin.
WD40 can lubricate my screen door so I just spray a whole can down my dipstick for every oil change.
Tranny oil is the same weight as motor oil, but because of emissions reasons oil companies are very limited in terms of what kind of additives they can put in motor oil. Tranny oils can be much more aggressive with additives because you're not going to be burning any.
Bottom line: Motor oil can do the job, but not as well. Given how infrequently you have to replace the tranny fluid, shell out the extra $5 and save your gears and synchros.
Old Sep 13, 2005 | 05:33 PM
Hondaman's Avatar
Hondaman
Black Pearl
:werd:
An extra $5 now could save you $hundreds later. Don't be cheap!
Old Sep 13, 2005 | 05:35 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
Correct me if I am wrong, but isn't tranny fluid for automatics and motor oil for manual?I've always used motor oil. Car runs great!!!
Old Sep 13, 2005 | 05:49 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
:a: Follow the goddamned owner's manual, for the love of Jesus Christ!
They recommend Honda Manual Transmission Fluid, not motor oil.
If you have to use motor oil, they strongly recommend switching back to Honda MTF as soon as possible.
Jumping Jesus on a pogo stick........ :doh:
Old Sep 13, 2005 | 05:53 PM
qtiger's Avatar
qtiger
There's MTF and ATF.
Old Sep 13, 2005 | 06:41 PM
dubcac's Avatar
dubcac
I
I've used 10-40 for about 4 years...no problems.
Old Sep 13, 2005 | 07:42 PM
psg-1's Avatar
psg-1
anything worth doing is worth doing right. everyone always says that hondas will run FOREVER if you just keep them properly oiled, so don't tell me you're gonna take a chance getting the only thing you have to do right, wrong.
Old Sep 13, 2005 | 09:02 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
I guess it is evident that I don't drive an automatic.
Old Sep 14, 2005 | 04:02 AM
Ninj4r's Avatar
Ninj4r
Acura Nubbins
Alright... well I agree it's definitley worth doing right the first time, which is why i've already spent like $6-700 on the stuff...
The way I was just told... was that our engines used motor oil instead of MTF...
And the people I spoke with seemed to incline that motor oil was what was expected.
"Honda" MTF will be fine for an aftermarket clutch right?
The new question is: Do you just hop down to a honda dealership to get their specific MTF? I need it by friday.
Old Sep 14, 2005 | 04:40 AM
EgRocker's Avatar
EgRocker
brain fart
at the auto store (kragen)i see that bottle of Lucas that helps manual transaxles lube better . it looks a little thin, should that be used in honda ? my synchros is giving out on me.
