$^@*#!!!! Urgent clutch help, please!
Old Aug 21, 2005 | 02:32 AM
psg-1's Avatar
psg-1
Originally Posted by VTEC-Power
Yea, I love ACT, and he is a very good seller. And labor usually is around $200-$300, becuase changing a clutch is a hassel
At least. labor charges can be insane. I called a guy to install my radiator and he quoted me $160something. Said the manual states 2.4hrs.
Needless to say I had a friend help out and paid him in... green. Saved $130.
Old Aug 21, 2005 | 07:00 AM
Ninj4r's Avatar
Ninj4r
Acura Nubbins
Any other suggestions as to what exactly is making it not work?
because if I can get a temporary fix, I may have to... swinging $900+ to have my clutch worked one... is going to be hard to pull off..
Old Aug 21, 2005 | 09:22 AM
VTEC-Power's Avatar
VTEC-Power
$900+ not worth it, just get a new tranny for that
Old Aug 21, 2005 | 05:52 PM
Ninj4r's Avatar
Ninj4r
Acura Nubbins
That's what I meant...
$900ish for:
ACT Stage2 clutch kit
8.8lb flywheel
Labor
Old Aug 21, 2005 | 07:03 PM
Hondaman's Avatar
Hondaman
Black Pearl
Sounds like a throw-out bearing to me.
Old Aug 21, 2005 | 07:32 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
It doesn't sound like a throwout bearing to me. A throwout bearing usually only makes noise when the clutch is completely out and the noise goes away as soon as the clutch pedal is touched. This is because the bearing has a load put on it by the release fork and stops making noise.
I would put my money on an out of whack diaphragm spring or something having to do with the pressure plate. Does it affect your shifting or clutch engagement, or is it just a noise?
For an ACT clutch, my best price I found for the HDSS and 8.8 lb prolite flywheel was $604 on ebay. ACT doesn't make clutches in stages; but instead, you can mix and match disk types and pressure plate types.
Old Aug 21, 2005 | 07:33 PM
Ninj4r's Avatar
Ninj4r
Acura Nubbins
I think it is the throwout bearing, because it only made the noise when the clutch was out, and then went away...
I don't really like "Stage" claims as is, it's just easier to say, I know they dont' go in stages over at ACT though... I was thinking the XTSS, over the HDSS, and a 12.5lb flywheel over the 8.8.... I know the roads aroud here too well, and tend to coast, I dont wanna stall all the time because I speed up and then coast the rest of the road.
Shmoo, if your around (since you just posted @ the same time as me)
Could you hop on AIM?
Old Aug 21, 2005 | 07:38 PM
Provocateur
On permanent hiatus
If the car isn't starting, the problem is not the throwout bearing.
Old Aug 21, 2005 | 08:11 PM
hitman619's Avatar
hitman619
SDSU Basketball
i have a 8.5 flywheel and act xtss clutch, and it does not die on me!!!!!!! here is a good web site clutchandflywheel.com got my set up for 610.00[
Old Aug 22, 2005 | 03:52 AM
Ninj4r's Avatar
Ninj4r
Acura Nubbins
and that "Indigo Speed Flywheel?"
how's that treating you?
