Just turbocharged the Type R
Old Aug 17, 2005 | 07:31 PM
5 Lug's Avatar
5 Lug
Default Just turbocharged the Type R
What's up guys. I finally took the plunge and turbocharged the Type R. Along with the complete turbo kit/parts I added a Fluidyne Radiator, Complete 3" Exhaust including 3" downpipe, new injectors and a fuel pump. This was dyno tuned with Hondata, I decided to go all out in one shot. Max Power= 289.63whp Max Torque= 187.39, all of this running at 7 psi. I don't intend to run any more boost until I upgrade the internals a bit. It runs strong right now so that's enough. I still have my A/C too. Here's some pics.....
Old Aug 17, 2005 | 07:33 PM
5 Lug's Avatar
5 Lug
Here's the info on the parts...
Turbo Kit:
Precision SC61 Turbo
Inline Pro Turbo Manifold
Tial 38mm Wastegate
Tial BOV
Precision 600hp IC
Full 3" Downpipe
Closed loop wastegate dump
Full LHT custom aluminum piping
Fuel:
AEM Fuel Pressure Reg.
AEM Fuel Rail
Precision 880cc Injectors
Walbro 255lph Fuel Pump
Engine Management:
Hondata S100B Standalone Engine Management
MSD 3 Bar Map Sensor
Big thanks to John, Scott, and Paul at LHT Performance for the install and tune.
www.lhtperformance.net
Old Aug 17, 2005 | 07:44 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Looks like you have a very solid setup there. It is good to see that you haven't skimped on the fuel management at all.
It looks like it is running very, very lean for a turbo setup with the super high compression an R has. You should be shooting for less than 12:1 and it doesn't even dip below that on the AFR chart. Maybe I am just on crack.... h:
Old Aug 17, 2005 | 07:58 PM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
That is fawking awesome! I now officially wish that I were you... JK.
But I'm afraid that Shmoo could be right about the compression. Of course it's possible that I too am on the crack.... h:
Old Aug 17, 2005 | 08:11 PM
5 Lug's Avatar
5 Lug
Wow, thanks guys. Thanks for the feedback on the Dyno Chart, I can't read it that well. It's funny you should say it looks to be running lean because it actually runs rich at start up, then when it warms up a bit it's at the end of stoich/beginning of rich section on one of those "rare top of the line, 100% accurate A/F gauges!!" haha, j/k. But that's what it says, anybody else's opinion on the dyno? Thanks again guys.
Old Aug 17, 2005 | 08:31 PM
bluetwo's Avatar
bluetwo
Hey welcome to the site brotha. I'm sure some other people will have more to say about it after a while. Just be patient I guess. Once again that is a beautiful car with a great set-up. :goodjob:
Old Aug 18, 2005 | 11:09 AM
Schwa's Avatar
Schwa
Schiggity
That is awesome. How much did the parts cost you. Also, are the injectors a little overkill for that setup or no?
Old Aug 18, 2005 | 04:52 PM
VTEC-Power's Avatar
VTEC-Power
Best looking Type R I have ever seen, I am jealous
Old Aug 18, 2005 | 05:26 PM
sherwood's Avatar
sherwood
I missed Sean
that is one badass machine you have there
Old Aug 18, 2005 | 10:03 PM
Provocateur
On permanent hiatus
As long as he can control them (which it looks like he did), it will put less strain on them since they have to run at a much lower duty cycle to maintain the same amount of fuel as smaller injectors. And it allows room for more boost, if desired.
