1998 Integra Manual Transmission Problem
Old Aug 2, 2005 | 04:12 PM
turbo_zone99's Avatar
turbo_zone99
Default 1998 Integra Manual Transmission Problem
Hi!
I'm having issues with my 1998 Integra LS transmission - the shift grinds going from 2nd to 3rd. I have to jigle a little bit to put it in 3rd gear, otherwise there will be screechy noise. Other gears are a little tight. Anyone has any idea or heard about this problem before. Per aamco, this is supposedly a common issue!
I first thought it was a clutch hydrolic issue, but the aamco guys are telling me the clutch is fine. They are saying either the tranmission has to be rebuilt or replaced. Makes any sense?
Thanks.
Old Aug 2, 2005 | 04:23 PM
dubcac's Avatar
dubcac
I
I think your 3rd gear synchros are toast...so yes, they would have to be replaced...which is going to cost you.
Old Aug 3, 2005 | 11:23 AM
turbo_zone99
Thanks dubcac!
I read somewhere I can get away with not fixing it for the moment if i "double clutch" correctly. But that's not my intention in case i can get it done for reasonably cheaper somewhere. Any idea how to get it fixed for cheap?
I took a quote from AAMCO - they told me its going to cost me anywhere from 2.5K to 3K+ depending whether the tranny needs rebuilt or replaced! Any suggestions, thoughts, comments... ??
Thanks.
Old Aug 3, 2005 | 11:38 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by turbo_zone99
Thanks dubcac!
Thanks.
You can pick up a used tranny for much cheaper than that.
Old Aug 3, 2005 | 11:58 AM
Tobra's Avatar
Tobra
I am just going to assume you changed the tranny fluid already. The price they quoted you is pretty high
Old Aug 3, 2005 | 12:29 PM
dubcac's Avatar
dubcac
I
You can pick up a used LS transmission for $4-500 if you look in parts classifieds. Labor would probably be 4-500, about the same as it would cost to have a clutch replaced.
