help...C.E.L light 70
Old Aug 4, 2005 | 04:19 AM
303_itr's Avatar
303_itr
No, the only aftermarket parts on the car is the headers and exhuast. Anyways, I finally brought it down to the usual shop to have them look at it and they are suppose to give me a call back today. I'll keep you inform. Thanks for all the help!...very much appreciated.
Old Aug 4, 2005 | 06:03 AM
teg92's Avatar
teg92
WHAT OK YEAH!
Originally Posted by 303_itr
I re-checked again and it still shows 70, seven same-speed flashes (automatic transmission) thanks for your help and input.
were they slow flashes or fast? It they were fast that means its code 7 and if they were slow then it would be code 70. You have to be doing something wrong here cause you shouldnt get a code for automatic transmission if you have a manual
Old Aug 4, 2005 | 08:08 AM
303_itr's Avatar
303_itr
got call back from the shop today...nothing is wrong with the car...possibily dirty intake, carbon buildup or something. Anyways, I'm gonna clean it and hopefully it doesn't happens again. Thanks for all the help! as for the code it was a '7' I guess the fast flashes just seems slow to me. Thanks again!
Old Aug 4, 2005 | 11:16 AM
94civicEX's Avatar
94civicEX
I got worms.
Long extended flashes = 10
Rapid flash = 1
You sure it isn't 7?
If it is 7, then it's your Throttle Angle Sensor.
Check your TPS sensor connections. Have you recently installed a VAFC or anything?
99 Integra GSR
06 TSX
duck squad member #00003
