help...C.E.L light 70
Old Aug 1, 2005 | 10:02 AM
303_itr's Avatar
303_itr
Default help...C.E.L light 70
Hello...my check engine light just came on I it returned with a CEL code of 70? Car is stock with the exception of header and 3" exhaust. Any idea why this is happening what can I do to correct this problem? your help is appreciated.
Old Aug 1, 2005 | 12:42 PM
sherwood's Avatar
sherwood
I missed Sean
it's a cel or a ce light, you are saying light twice, lol
Old Aug 1, 2005 | 02:55 PM
94civicEX's Avatar
94civicEX
I got worms.
70 Automatic Transaxle
Which doesn't make any sense cause you have a manual car. Re-check the code. You sure you did it right?
99 Integra GSR
06 TSX
duck squad member #00003
Old Aug 1, 2005 | 03:09 PM
303_itr's Avatar
303_itr
yeah...I tripled check...seven flashes (same speed) then nothing after that...then it repeats the same seven flashes. This sucks....Thanks for the help though!
don't know if this helps but a few days ago, this happened months before also, while I was cruising at about 45 mph in 4th the car seem like it was slowing down slightly, rpm and mph guage didn't drop more than 100 rpm, but I could feel the gas pedal lose a little pressure before going back to the previous position.
Old Aug 1, 2005 | 03:59 PM
94civicEX's Avatar
94civicEX
I got worms.
Is your car a swap or is it the original motor?
99 Integra GSR
06 TSX
Old Aug 2, 2005 | 05:54 AM
303_itr's Avatar
303_itr
it's a 00' integra type-r. I know the itr is infamous for the synchros and/or tranny going bad, could this be the issue?
Old Aug 2, 2005 | 06:02 AM
teg92's Avatar
teg92
WHAT OK YEAH!
you wouldnt get a check engine light if your synchros or tranny went bad.
Old Aug 2, 2005 | 09:59 AM
94civicEX's Avatar
94civicEX
I got worms.
I suggest rechecking. You sure it isn't 71?
99 Integra GSR
06 TSX
Old Aug 2, 2005 | 12:49 PM
303_itr's Avatar
303_itr
I re-checked again and it still shows 70, seven same-speed flashes (automatic transmission) thanks for your help and input.
Old Aug 2, 2005 | 01:44 PM
94civicEX's Avatar
94civicEX
I got worms.
Long extended flashes = 10
Rapid flash = 1
You sure it isn't 7?
If it is 7, then it's your Throttle Angle Sensor.
Check your TPS sensor connections. Have you recently installed a VAFC or anything?
99 Integra GSR
06 TSX
