kill switch
Old Jul 24, 2005 | 03:03 PM
sherwood's Avatar
sherwood
I missed Sean
Default kill switch
i was wondering how to go about installing a kill switch in my teg... do i just install a low-voltage switch in line with the ignition wires and then put it somewhere or is it more in-depth?
:edit:
or would it be better to connect it to the clutch (isnt there a switcht hat tells the car when the clutch is depressed before it can turn on?)
Old Jul 24, 2005 | 07:54 PM
tonysstudio's Avatar
tonysstudio
I got one on my site.
http://www.tonysauto.org/pages/Kill%...%20Install.htm
Old Jul 24, 2005 | 07:59 PM
foot's Avatar
foot
I'd install the switch in series with the "ON" wire from the ignition switch.
Old Jul 24, 2005 | 09:31 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
And then someone hotwires your car and its worthless.....
Old Jul 24, 2005 | 10:01 PM
Integral's Avatar
Integral
Nightmare Motorsports
Nice write up on the page... think I am going to go about hooking one up very soon.
Old Jul 25, 2005 | 11:04 AM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
If you use a fuelpump cutoff switch, I highly using a relay at the locaion of the pump, and using a switch to control the relay. reduces resistance on the fuel pump wires.
Old Jul 25, 2005 | 11:41 AM
honura's Avatar
honura
Seni
My friend just hooked one up to his rear driverside window switch on the drive door. I think NO ONE will ever look there.
Old Jul 25, 2005 | 12:12 PM
Epoch's Avatar
Epoch
Actually, windowswitches are a very common place to do starter interrupts. I think most theives would look there first or second in their attempt to find it
Old Jul 25, 2005 | 12:31 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Exaaaaactly. That's how I would do it for sure. It would also benefit you to just run the fuel pump directly to the battery (the wiring) then as a direct line is more efficient. Something to consider.
Old Jul 25, 2005 | 02:36 PM
sherwood's Avatar
sherwood
I missed Sean
i can deal with the placing of the switch, my question is how do i go about wiring it in.. i want to keep it simplistic... so basicaly wha ti'm asking is there or isnt there a switch running to the clutch already to tell the car it's being depressed all the way
