Intake + water = bad
Old Jun 30, 2005 | 09:18 AM
VTEC-Power's Avatar
VTEC-Power
I'm not saying he does, I was just saying he probabally has water in there still
Old Jun 30, 2005 | 05:57 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
i think his engine is done . Lets hope for the best though
Old Jun 30, 2005 | 06:54 PM
sherwood's Avatar
sherwood
I missed Sean
if water got into teh engine and it hasent siezed yet he might be able to flush it out with oil or something.... all is not lost
Old Jul 1, 2005 | 10:23 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Default Alright Guys, let's hold off on the hypotheticals..
Gentlemen,
Until the OP returns with the CEL codes, we can't do anything but guess.
I personallly, have a hunch that he'll come back with "Cylinder Misfire" codes.
Since the motor still runs, he's probably dodged a bullet and only needs new spark plugs.
That said, I have to address two comments..
Not to bust balls, but you just said....
take off your manifold you might still have water in there
:nono: No. No. No. Talk about mis-information...
The absolute last thing you want to do is start dumping more fluids into the combustion chamber. That is a guaranteed way to compound the damage.
At best you'll blow a head gasket...at worst, you'll buckle a con-rod or demolish pistons.
Old Jul 1, 2005 | 05:46 PM
Integral's Avatar
Integral
Nightmare Motorsports
Well said Dave! Yes, at this point its cross your fingers and hope for the best, until he returns with codes...
Old Jul 1, 2005 | 07:21 PM
sherwood's Avatar
sherwood
I missed Sean
i didnt mean litterally flush it out with oil....doesnt water eventually make it's way tot he oil pan and then gather blow the oil where it is picked up and thrown into the engine in major quantities? i'm no expert but i would assume thats what can happen...
Old Jul 3, 2005 | 08:48 AM
integratuner55's Avatar
integratuner55
well the check engine light went out. the sound went away so i think all the water's out. My friend's dad (mechanic/junk yard owner) said that it takes 50 miles for your car CEL to go off if there's no longer a problem with you car. So as i see it, its fine now. Thanks guys
Old Jul 3, 2005 | 09:06 AM
VTEC-Power's Avatar
VTEC-Power
well when I sucked up water My Intake manifold had water in it, my oil had water in it, and water warped my pistons and I never got a CEL
Old Jul 3, 2005 | 11:51 AM
TheOtherDave™
Apathy Kills
It sounds like you got lucky, but I'm not entirely convinced.
CEL codes do not clear based on mileage.
Did you ever retrieve the code?
Old Jul 3, 2005 | 12:11 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
wow you got lucky
