Motor decision
Old Jul 21, 2005 | 10:27 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Originally Posted by dubcac
Power steering and AC can be retained with an H22 swap...just have to buy some CNC'd AC and PS brackets...I forget who makes them. And if you're gonna get a B20Z and just rebuild it, might as well get the B20B...cheaper and much easier to find.
Duly noted. My main point was cost-effective power.
The H22A is fetching about $3K for a JDM H22A vs. $900 for a B20B.
It's not the rods that have the problem, it's the rod bolts. Upgrade those alone, you're good to 8k reliably. I know firsthand what the stock rods can do...my roommate had an LSVTEC with ARP bolts and shotpeened OEM LS rods...9500 rpm all day. He also had a balanced rotating assembly, and used the crank girdle.
That's an impressive feat.. 9500 on a B20 w/ stock bore & stroke! :eek3:
Old Jul 21, 2005 | 01:53 PM
dubcac's Avatar
dubcac
I
H22A's can be had for a decent price, usually quite a bit less than a GSR. However, you'll need axles (I'd recommend custom) and mounts, and it takes a bit of work to swap them in.
I agree, the B20 is the best swap, offering lots of options...N/A nonvtec, CRVTEC, boost, nitrous.
It was actually an LS crank and Rods in a GSR block, .25mm overbore...but yes, 9500 rpm on stock LS rods, with ARP bolts and shotpeening. The rods are surprisingly strong.
