will 94-01 greddy turbo ls kit bolt on my 2000 gsr
Old May 30, 2005 | 07:49 PM
  #91
TeHJuSTiN's Avatar
TeHJuSTiN
NAM #0001
Originally Posted by greengsr2k
yes we bled the manual transmission fluid . We drain the fluid . But Its so damn hard to put in any gear when idle, but shifts fine when in motion.
What kind of fluid did you put back in?
Old May 30, 2005 | 08:13 PM
  #92
Provocateur's Avatar
Provocateur
On permanent hiatus
No, I mean the clutch fluid. You have to drain the tranny fluid anyway, but it might help if you bleed the clutch system.
Old May 30, 2005 | 08:32 PM
  #93
greengsr2k's Avatar
greengsr2k
i dont think we bled the clutch system. How do you bleed the clutch system???
Old May 30, 2005 | 08:37 PM
  #94
greengsr2k's Avatar
greengsr2k
we put in honda manual transmission fluid
Old May 30, 2005 | 09:41 PM
  #95
Provocateur
On permanent hiatus
You hook a hose and bottle up to the little 8 or 10 mm nipple on the slave cylinder. Loosen the valve and have a buddy pump the clutch pedal and then pry it off the floor. Make sure the reservoir is full at all times to prevent air from getting in the lines. Tighten the bolt back up, add fluid, and then repeat the process. Do this until clear fluid comes out of the hose.
It isn't necessary to bleed the clutch system after a clutch install, but it may help in your situation.
Old May 31, 2005 | 08:52 PM
  #96
1.8Tintegra's Avatar
1.8Tintegra
Default Greddy kit
just to let you know there is a difference between the Ls/Gs kit and the GSR turbo kits.
Check out www.city-speed.com for great deals and more info, i bought my kit from them GOOOOOOD PRICES
Old May 31, 2005 | 09:06 PM
  #97
Provocateur
On permanent hiatus
Yes, there is.
As a matter of fact, I purchased my kit from him and I recommended him to greengsr2k, who then purchased his kit from him.
Old Jun 1, 2005 | 06:11 AM
  #98
greengsr2k's Avatar
greengsr2k
I bought my kit from them ls version. The difference between gsr is the shorter lenght downpipe and different position of the manifold and also the blue box.
Old Jun 2, 2005 | 11:16 AM
  #99
greengsr2k's Avatar
greengsr2k
Shmoo, i have good news . My gsr is almost fully installed. Fmic turbo manifold are all in. The guy working on my car just needs to weld on the bov and weld the return line on on oil pan today and everything should be done ,The charge pipe needs to be connected and downpipe and thats it. He will also street tune with Crome Pro my car for 2 hours before i hit dyno. I will try to post pics later.
Old Jun 2, 2005 | 12:48 PM
  #100
Provocateur
On permanent hiatus
I hope you have a wideband O2 sensor for that street tuning.
