Problems starting on a new turbo install
Unfortunately I do not have any friends with a gsr. I believe that I am using a 6 psi spring, but i could be completely wrong, and didn't check the one time i got the car started. I think I am gonna give up and just take it to a shop and let them mess around with it, because I am too busy with school, and my beater broke down. Maybe they'll figure it out.
do you have full msd ignition ,the box ,coil, wires. If you do and you hooked up the msd timing control unit you got to make sure that the timing control unit is made for msd ignitions they have two one for msd ignitions and one for stock same problem I had I had to buy the one 4 msd ignitions hope this helps
My car did the exact same thing when I put in my turbo. I changed you the wires spark plugs, rotor. Checked everything and nothing would work. I got a new coil and the car started fine after I put that in.
