Danger putting 23mm rear sway bay in NON-Type R Teg??
Old Feb 16, 2005 | 01:55 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
Originally Posted by Solracer
Yep that is correct, switch thoose spring rates and see what happens, which if I was auto-xing or racing on a road course that is exactaly what I would do.
5kg/mm front and 10kg/mm rear with the comptech sway-tie combo? That would cause the car to be a death trap h:
Currently, I'm rocking a style that's popular with japanese Gymkhana racers, without the extreme camber. Very streetable with a very neutral feel. Before I had put the coilovers on, though, I had the comptech installed for nearly a year, and with it on the medium setting, it was very predictable, but a little shakey in rain. I reccomend going with the medium setting max if you standard springs, then going to hard if you have nice and balanced aftermarket springs.
Old Feb 16, 2005 | 02:12 PM
LT's Avatar
LT
The deer had to die!
H&R Race springs + KYB AGX + Comptech sway bar = teh win!
Old Feb 17, 2005 | 06:10 AM
Solracer's Avatar
Solracer
NASA-VA Hyper-Announcer
Originally Posted by Epoch
5kg/mm front and 10kg/mm rear with the comptech sway-tie combo? That would cause the car to be a death trap h:.
A lot of the road racers I know with hondas run stuff like 500lbs springs inthe front and any where form 800 to 1200 lbs springs in the rear with a large sway bar, this defintaly will make the car loose and rotate very fast.
Old Feb 17, 2005 | 02:43 PM
carta79's Avatar
carta79
Life after death
Originally Posted by LT6916
you know, i've never experienced unpredicted, uncontrollable snap-oversteer.
but i'm sure my spring rates help with that.
I have man and it fuggin sucks.
Old Feb 17, 2005 | 05:04 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
too be honest, I had more problems with snap oversteer back when my civic was bone stock (with worn rear suspension bushings) than I do now 380f/400r springs, 21mm swaybar front, 22mm rear.
Old Feb 17, 2005 | 05:25 PM
Tobra's Avatar
Tobra
Only snap oversteer I ever felt was in a rear engine car, porsche and VW. Lift off the loud pedal and watch out! If you pay attention and know how to drive even moderately well, you will be okay. Your dollars would be better spent on a driving course, IMHO. Learn to get the most out of what you have before making any big changes.
Old Feb 18, 2005 | 09:25 AM
Solracer's Avatar
Solracer
Originally Posted by Tobra
Only snap oversteer I ever felt was in a rear engine car, porsche and VW. .
You have never seen/experience lift thottle oversteer on a FWD Car???? It can happen very very easily, of course I see it a lot on track and at autocross's I saw it once on the street.
I will still stand by this statement, if you are not going to auto-xing or driving on track, the TYPE-R sway upgrade is too big of a risk, even with reinceforment kits they will rip out evetually espically with stock or low rear springs rates, so why risk it?
Old Feb 18, 2005 | 09:32 AM
LT's Avatar
LT
i'm safe from any of that, but the warning is welcomed to others.
Old Feb 18, 2005 | 09:39 PM
ihighro11eri's Avatar
ihighro11eri
i have the type r rear sway on STOCK suspention, and it feels great.... snap oversteer is mostly for the unexperienced.... dont panic and just floor your way out...
Old Feb 22, 2005 | 04:44 PM
Aracheon's Avatar
Aracheon
I > joO
So does the risk of the sub-frame tearing out become lower if one does suspension?
