help, integra has a weird starting problem
Old Jan 8, 2005 | 08:43 PM
j87w's Avatar
j87w
Default help, integra has a weird starting problem
I have a 95 LS 5 speed integra. I just put a brand new starter on it when I put my new tranny in. The last time I put a clutch and a flywheel it did the same thing. This time it didnt fix it self though. My problem is that I turn the key and the car wont start. I can jump the car using a wire off the starter terminal to the battery. I put my clutch relay in my friends car and his started right up. I pushed the wires around under the column to try to see if it was a loose wire, and I could possibly get it to work like that. That didnt work. So I got a wire from the key switch where it says start or whatever and held it there to the starter, turned the key and it started. I was pretty much just bypassing the clutch saftey switch. I checked the starter fuse (7.5 under the column). So that elimininates it being the starter, relay, fuse, and the key switch. Then I put a wire from the clutch saftey switch and just made a circuit out of it. Still no start. I cant figure it out. Sorry that was pretty long. Anyone got any ideas?
Old Jan 8, 2005 | 09:17 PM
dubcac's Avatar
dubcac
I
What happens when you turn the key but it wont start...does it try to crank, or nothing happens?
Old Jan 8, 2005 | 09:39 PM
j87w's Avatar
j87w
No, nothing happens. If I hook the wire up from the keyswitch to the starter, It starts right up.
Old Jan 8, 2005 | 10:00 PM
dubcac's Avatar
dubcac
I
It's probably your clutch switch. I had a similar problem with my car, occasionally it would start...sometimes I'd turn the key and nothing would happen...no click, no nothing. If it wasn't starting, I'd just let the clutch out a fraction and turn the key...would start right up. My problem went away all by itself over time.
Old Jan 9, 2005 | 12:08 AM
j87w's Avatar
j87w
I guess ill replace the clutch saftey switch. I thought it would make it work though. I just found it weird that after I pull the tranny it does this. Cant you hook up a wire into the plug that comes off of it and bypass it. I did that but it still didnt start. The factory service manual says to put a wire in the plug and push in the clutch and if theres continuity then its good. I havent tried it yet but well see. Does anyone know a way to bypass the clutch saftey switch. My next step is to get a test light and follow the wire till I find the problem. I would rather just test the saftey switch first though.
Old Jan 9, 2005 | 10:25 AM
dubcac's Avatar
dubcac
I
Check in the electronics forum or ask someone who has installed a remote start on a manual car...they have to bypass the clutch safety switch in order for the remote start to work.
Old Jan 9, 2005 | 10:29 AM
EvanG23's Avatar
EvanG23
Kid w/ No Money
Just park on a hill... take off your e-brake... start rolling... throw it into first... drop the clutch... and don't lock your knees... works everytime..
