ITR differences
Old Jan 7, 2005 | 01:39 PM
94civicEX's Avatar
94civicEX
I got worms.
This has been covered quite a few times, here are two good posts.
Okay, I am going to list all of the differences and then I am closing this thread.
Exterior
Available only in Championship White ('97); Phoenix Yellow or Flamenco Black Pearl ('98, '00-'01)
Front lip spoiler
Red 'A' emblems
Integra Type-R badging on side panels and hatch
Rear wing spoiler
No rear wiper
Interior
No sunroof
Grey suede seats with red stitching
Black leather shift boot with red stitching
Billet alumiunum shift knob with red H-pattern labeling
Stereo and a/c optional ('97)
Removed sound deadening material
Wheels & Tires
Gunmetal finish 7-spoke 15" 5-lug wheels with red 'A' center caps
195/55-15 Bridgestone Potenza RE010 tires
Suspension
Stiffer shocks
Stiffer springs
22 mm rear sway bar with different attatchment points
Higher durometer rubber bushings
Brakes
Larger front rotors and calipers
Body structure
Front strut tower brace
Extra bracing in various body panels, thicker-gauge steel
Spot welding throughout shell for stiffness
Engine
Engine code changed to B18C5
Different intake path
Larger throttle body
Fixed runner-length intake manifold with large plenum and short runners
Port & polish on head
Higher lift and duration cams
Stiffened valve springs
10.6:1 compression ratio pistons
Raised redline
Red valve cover
Upgraded exhaust manifold, slightly more free-flowing muffler
Transmission
Lightened flywheel
Close-ratio gearbox
Helical limited-slip differential
Originally Posted by Asahi
Here are a few corrections and additions.
Exterior
Available only in Championship White ('97, '98)
Phoenix Yellow or Flamenco Black Pearl ('00-'01)
No rear wiper ('97 Only)
Front and Rear bumper change in 1998 (All other Integras got this)
Interior
Black suede seats with red stitching
Black leather shift boot with red stitching (Not so, only on JDM Type-R's)
Leather Shift knob with Red Stich ('97, '98)
Billet alumiunum shift knob with red H-pattern labeling ('00, '01)
Faux Carbon Fiber Guage Cluster ('97, '98, '00, '01)
Faux Carbon Fiber Trim on center console and vents ('00, '01)
Stereo optional ('97)
a/c optional ('97 and '98)
Wheels & Tires
Championship White paint 15"x6" 5x114 ('97, '98)
Gunmetal finish 7-spoke 15" 5-lug wheels with red 'A' center caps ('00, '01)
Body structure
Lower Rear Tie Bar
Rear Strong Bar in Trunk
Additionally:
One of the major chassis improvements to the Type R are the front and rear anti-roll bars (also called sway bars) located underneath the car. The front uses the same size 24mm sway bar as the GS-R, however on the Type R the bar is a ball-joint type which mounts to the car and gives the highest degree of rigidity. The rear raises the standard as a 22mm sway bar replaces the 14mm sway bar equipped on the GS-R. The larger rear sway bar allows for much less body roll and decreases understeer to a dramatic degree to give the Type R almost neutral handling.
1. Aluminum front strut tower bar. The bar has been made stiffer than the GS-R's strut tower bar in order to more tightly hold the unit-body chassis together and minimize chassis flex up front. The bar has also been given a polished silver finish complete with a "Type R" decal to enhance engine bay looks.
2. Larger upper pillars and a thicker roof rail have been added to increase safety in the event of a high speed collision resulting in a roll-over (this is a track car remember).
3. The rear wheelhouse and arch extension have been made thicker and stronger to increase overall stiffness in the rear and help reduce understeer.
4. Thicker rear damper gussets have been equipped to handle the increased coilover stiffness and sway bar size.
5. The rear lower arm bracket has been strengthened to meet the demands of the larger 22mm sway bar.
6. An aluminum tie bar has been fitted to the rear crossmember to better hold the unibody chassis together and minimize chassis-flex in the rear. It functions similar to the strut tower bar up front (1) only it connects the underside of the suspension together rather than the top. A rear strut tower bar is equipped on the JDM models however it was deleted for the U.S. model.
7. Another polished aluminum bar has been attached to the absolute rear of the chassis to aid in minimizing chassis flex in the rear.
as found here: http://www.team-integra.net/sections...p?ArticleID=37
File Type: jpg
99 Integra GSR
06 TSX
duck squad member #00003
Old Jan 7, 2005 | 01:52 PM
Nelson's Avatar
Nelson
Administrator
Awesome info! :bigok:
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Jan 7, 2005 | 02:37 PM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
Yep. Now that was what I was hoping for.
So trying to make a GSR a Type R isn't just a few simple bolt-ons, but give your GSR the Type R engine and stiffen it up really good and you're cookin with crisco!
Just, I wouldn't put red emblems on it.
Old Jan 7, 2005 | 04:28 PM
LT's Avatar
LT
The deer had to die!
you should've given credit to the sight you got that from chancy h:
Old Jan 7, 2005 | 04:41 PM
94civicEX's Avatar
94civicEX
I got worms.
ya ya ya
99 Integra GSR
06 TSX
