ITR differences
Old Jan 6, 2005 | 06:35 PM
lazyboi's Avatar
lazyboi
Default ITR differences
Hey I'm not sure if this should be in the Integra or the ITR forum. But I wanted to know the exact differences between the two cars. I have one LS and one GSR, One of those I want to convert into an ITR (Probably the GSR). My LS I am thinking about going LS/VTEC with using the GSR motor. I will be purchasing a front clip. But I just wanted to know what other differences. like what suspension parts exactly and whatever I don't know. Thanx
Old Jan 6, 2005 | 06:38 PM
LT's Avatar
LT
The deer had to die!
the ITR chassis has reinforcments that other trims do not:
-thicker metal around the rear wheel wells
-thicker b-pillar
-rear LCAs are thicker
-different subframe
-better dampeners
-progressive rear springs
it really goes on...
bluetwo's Avatar
bluetwo
Relevance is irrelevant
I think the ITR suspension is considerably different, but I don't really know the specifics.
I hope you get a bunch of good responses.
Old Jan 6, 2005 | 07:41 PM
Snoopy's Avatar
Snoopy
been there done that
http://www.team-integra.net/sections...les.asp?Show=5
you may need to sign up there to read it, well worth it.
Old Jan 6, 2005 | 07:46 PM
99IntegraGS's Avatar
99IntegraGS
Actually, it's not that different. Maybe the spring and dampening rates are different, but the suspension swap is not that big a deal. My GS has ITR springs, shocks/struts, lower control arms and an ITR rear swaybar. The swaybar is the only part that required much custom work to use (BEAKS kit). To use ITR rear struts I had to swap out my GS LCA's for ITR LCA's. The swap lowered my car very slightly and gave it a much firmer ride.
JD
Old Jan 6, 2005 | 08:02 PM
neeman77's Avatar
neeman77
from the sounds of this I hope you are not doing this yourself. LS/VTEC doesnt mean putting a vtec motor in an LS. Its adding vtec your existing LS engine.
Old Jan 6, 2005 | 08:15 PM
ADRONICUS's Avatar
ADRONICUS
www.ufc.com
You could probably sell both cars and buy a Type-R and have something left over as opposed to the money your gonna spend converting it over.
Old Jan 6, 2005 | 08:17 PM
bluetwo's Avatar
bluetwo
Yes! ITR with something left over = > one LS and one GSR swapped and chopped.
Old Jan 7, 2005 | 10:10 AM
lazyboi's Avatar
lazyboi
? Ummm I'm using the LS block and the GSR head...
Old Jan 7, 2005 | 10:11 AM
lazyboi's Avatar
lazyboi
Nah I'd rather modify then buy :-P
