most power for the buck?
As long as the PS rack remains lubbed it will be fine. The reason for the breather as opposed to a standard loop is that the fluid has a place to go as the piston in the rack moves from side to side.
Tom
So you just stuck a breather on each end of the rack where hoses used to be? You don't think a loop will work? I am pulling off probably this weekend, the rest of power steering stuff. Also what is the ratio on the manuel rack, and what rack will fit all I have found is power racks for integras.
Originally Posted by Katana950
Tom
I also have one breather, both lines off the rack are T'd off into one line that leads to the breather.
Do you leak fluid out of the breather?
Why did you run the breather all the way up there and not just have it down by the rack itself? It seems to me that it would have been simplier to just T it off and then attach breather down by the rack less hose and less fluid to mess with.
Originally Posted by h22afreak
high comp LS/vtec that should give you good power gains
and you get to keep it allmotor no turbo head aches.
