Stroker Kit
Old Oct 9, 2004 | 03:47 PM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
I love torque.
Old Oct 10, 2004 | 12:56 AM
dubcac's Avatar
dubcac
I
Originally Posted by NorCal DC4
In order to seat the block lower, you'd probably need to convert to a dry-sump oiling system. Then modify the engine mounts to reposition the motor and tranny a scoshe lower. h:
Might as well go with a K-series swap (once they work the bugs out). h:
Okay, enough bench racing. h:
I'm the kinda person that would rather do that than swap in a kseries...just to say I did it...could always just get a hood with a slight cowel in it.
Old Oct 10, 2004 | 08:19 PM
exospeed*com's Avatar
exospeed*com
Originally Posted by GSRRacer95
I'm getting ready to rebuild my spare b18c1 and I was thinking about stroking it to a 2.26ltr. What are your opinions on stroker motors?? Thanks!!
Stroker motors arent for everyone. We believe that stroking the motor should only be done in a HARDCORE street application or a Race Engine Setup. Street cars don't need to stroke the motor and HP increase isnt worth it with respect to reliability and driveability.
Another good way to make power is a bigger bore. I would suggest an 84mm GSR block which will make it about 2.0L I know it isnt 2.26, but what are your goals anyway. If you arent reaching for over 250hp on the street, then a basic big bore block with stock crank is good enough and can make 230 easily. And thats plenty enough for the street. To start making 240+, thats when you are increasing compression, going bigger than 84mm, requires race gas and decreases reliability.
A Stroker motor is easy to think up and design. but what differs it from your basic build up is that it requires a different Crank or modified stock one. Custom rods and also possibly custom pistons. You have to realize that COST will go up significantly for a stroker motor. You have to think if the extra $1000-1500 on top of a basic $2800 sleeved built block is worth it enough so you can complete a stroker motor.
Old Oct 10, 2004 | 09:04 PM
dubcac's Avatar
dubcac
I
Unless he can find a stock crank from an old prelude b20a.
Old Oct 10, 2004 | 11:37 PM
exospeed*com
B20A cranks is totally different and wont work on the B18A/B, /B20B-Z blocks.
Old Oct 11, 2004 | 05:17 AM
carta79's Avatar
carta79
Life after death
I agree with this guy.
Old Oct 11, 2004 | 09:46 AM
dubcac's Avatar
dubcac
I
Really, because I've heard of people using it before.
Old Oct 11, 2004 | 10:11 AM
carta79's Avatar
carta79
Life after death
I thought that any B series Honda crankshaft will fit in any B series block. With minor machining to allow for adequate clearance for some cases. :dunno:
Old Oct 11, 2004 | 07:24 PM
exospeed*com
If the old B20 cranks did fit, you know I'd have a shelf full of them by now or you'll hear Actualy people using them.
People talked about it before but the actual journal size is different so it wont work as a drop in crank.
