Starting Issue
Old Sep 29, 2004 | 10:17 AM
badboy58's Avatar
badboy58
Default Starting Issue
So my car is having this problem, and I have talked to a few friends, but no good answers. Here is the prob. Sometimes when I go to start my car, usually after sitting in the parking lot at work all day....it doesnt want to start. Keep trying and nothing. Sometimes it will start up, rev to 2k rpm, then die. If I leave it for a while (meaning like 30 min) it will start. Now my the thing is, it is happening more now. It happened after work last night, and just now as I was trying to go to lunch. I have no problem from a cold start in the morning. It is just after work or whatever. I checked everything, the battery is new, spark plug wires all connected good, terminals on battery are fine, has fuel - coolant - oil. Dont know what else to check. Please let me know what you think.
Old Sep 29, 2004 | 11:51 AM
fjm1's Avatar
fjm1
G35
do a search on "hot start" lots of info
possibly temp sensors or pgm fi relay.
Old Aug 19, 2005 | 11:13 AM
AcuraHolt's Avatar
AcuraHolt
Default I'm having this same problem..what did you find out
I read your post and am having the same exact problem on a 93 Acura Vigor....what did you find to be wrong? Thanks for any help.
Old Aug 19, 2005 | 04:45 PM
raihan.f1's Avatar
raihan.f1
I think its your main relay here, have that same intermittent problem in my Integra. One thing to note is it almost never happens in the morning.
Old Aug 21, 2005 | 09:59 PM
Tanker's Avatar
Tanker
Originally Posted by badboy58
Sometimes when I go to start my car, usually after sitting in the parking lot at work all day....it doesn't want to start. Keep trying and nothing.
It's probably because you rolled up your windows. This expands the relay joints, creating an open circuit. Turn on the ignition then listen for the 2 seconds fuel pump hum at the gas filler. If you don't hear it, the relay is out cold.
This is because the fuel rail is still pressurized. The quick fuel cut-off spikes tach readings.
Here are some good sites.
http://techauto.tripod.com
http://www.marklamond.co.uk/howto/el...main-relay.htm
http://www.tegger.com/hondafaq/start...html#mainrelay
Old Aug 22, 2005 | 02:49 PM
toplineauto's Avatar
toplineauto
Default starting problems
Try turning the key until just before it starts, which will prime the fuel pump. Also, don't let the gas get too low or your fuel pump which is in the gas tank may overheat.
By the way, anyone have problems with random movements of the speedometer?
Thanks
Old Aug 22, 2005 | 03:04 PM
badboy58's Avatar
badboy58
It was my ECM, this is the site i used to fix mine....http://www.integra.orcon.net.nz/relay
Old Aug 22, 2005 | 03:14 PM
toplineauto
Default Starting?
your starting problem or MY speedometer problem?
Old Aug 22, 2005 | 03:17 PM
badboy58's Avatar
badboy58
my old starting problem
Old Aug 25, 2005 | 05:54 PM
bboy's Avatar
bboy
gixxer ryder
DISTRIBUTOR is what you guys need
