b18b vs.b18a ?
Old Sep 17, 2004 | 08:06 AM
nik_rek's Avatar
nik_rek
sabaidee!
Default b18b vs.b18a ?
What are differences? beside being a different year.
I'm going to do a b18b swap in my civic and I came upon a b18a swap for alot cheaper
Old Sep 17, 2004 | 08:13 AM
RB's Avatar
RB
snitches get stitches
not a whole lot...actually, pretty much nothing at all.
Old Sep 17, 2004 | 08:17 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
The B18A made less power, and had a marginally lower redline.
The B18A had less static compression compared to the B18B, and the stock cams were more conservative.
But the problem goes further than that when you're looking to swap....
In CA, you cannot put an older motor in a newer chassis and expect to pass smog.
Instead, the engine must be from the same year as the target car or newer, and every last emissions component must be tranferred to the target car.
Check your state emission laws first -- before you buy the older engine.
I'll be very surprised if New York State doesn't have a similar law.
Old Sep 17, 2004 | 08:34 AM
ISP James's Avatar
ISP James
DAMIMRED
one of these threads seems to surface every what.... two weeks, maybe?
we dont have to pass smog in NY, chances are nobody will ever know the diff if you have a b18a in a 94+ chassis...
Old Sep 17, 2004 | 11:52 AM
intjinfj's Avatar
intjinfj
Thank goodness for living in Indiana and not having to check emisions BUMP!
Old Sep 17, 2004 | 05:02 PM
Kai's Avatar
Kai
Rotorphile.
As far as I can tell, all 90-01 B18A/B engines had a 9.2:1 static compression.
Anyway, the main difference is in the 90-91 B18A, it's was a little lacking at 130hp, 121lb-ft. The 92-93 B18A was rated at 140/126, and if memory serves, the B18B varied from 142/126, to 140/126, then I could have sworn I saw a sticker on '00 and '01 models dropping it down to 138/126 thanks to emissions laws.
Anyway, stick with a 92-up engine unless you want to swap a pair of newer cams into a 90-91.
After modification, they're all the same.
Old Sep 17, 2004 | 05:15 PM
nik_rek's Avatar
nik_rek
sabaidee!
thanks for the input guys
Old Sep 17, 2004 | 05:34 PM
k.a.y's Avatar
k.a.y
yeah, man....if it's signifigantly cheaper go w/ the b18a. That's what i've got in my '92 gs, and w/ 168k miles on it, it still pulls like new.
Old Sep 19, 2004 | 07:04 PM
Twiz's Avatar
Twiz
Also dont forget most b18a1 motor swaps come with cable style trans vs. the hydro trans in the 94-up. Also would have to change injectors, distrib and a few other sensors to make it odb1 unless it is from a 92-93 integra.
Old Sep 20, 2004 | 12:55 AM
95tegRS's Avatar
95tegRS
try the search button, tons of info there!!
