Vibrating steering column
Old Jun 4, 2004 | 10:50 PM
maldini's Avatar
maldini
Default Vibrating steering column
My steering column vibrates or at least there is some some strange clunking sound on the left side on accleration. What could be the problem?
What parts are involved to transfer the power from the engine to the wheels? I suspect something is loose. Please help.
Thanks
Old Jun 6, 2004 | 03:46 AM
savco-integra's Avatar
savco-integra
do u mean that while your driving the steering wheel shakes?
Old Jun 6, 2004 | 09:08 AM
Daniel's Avatar
Daniel
Engine > Flywheel > Transmission > Axles > Wheels
Have you inspected all CV joints, both inboard and outboard? Look for tears in the rubber boots and grease flung about.
Old Jun 7, 2004 | 04:58 AM
borateen's Avatar
borateen
When was the last time you had your tires rotated and balanced?
Rob R.
Old Jun 7, 2004 | 07:39 AM
kiddo118's Avatar
kiddo118
I have this same problem but my steering wheel does not shake and the rotational vibration is felt throughout the entire time I drive. I'm leaning towards my axles because the last time I was under the car, I saw a bit of grease on the joints but didn't think much of it because I thought they just didn't clean up after the job. I'm still trying to figure out exactly what it is causing this pulsation.
Old Jun 7, 2004 | 07:41 AM
KAUAI KANE's Avatar
KAUAI KANE
91' Toyota Supra
From: Iwakuni, Japan. And where ever the Marine Corps sends me
could be bearings as well but my money is one the cv joints/ also balance your tires that will help as well
Old Jun 8, 2004 | 12:15 PM
teg_fan's Avatar
teg_fan
I like integra's
ALIGNMENT, or cut the rotors if it happens under braking
Old Jun 8, 2004 | 06:59 PM
kiddo118's Avatar
kiddo118
Okay can someone tell me what are the symptoms of a broken axle or leaking cv boot/joint? I don't feel it only when braking but during the whole ride. It's something ticking felt on the pedals/steering wheel and underneath driver's side.
Old Jun 8, 2004 | 08:12 PM
timmy8151's Avatar
timmy8151
Jack up your car and see if your boots are torn or leaking.
Old Jun 9, 2004 | 10:41 AM
maldini's Avatar
maldini
Rob R.
My tires were balanced when I bought new tires for the car. But this problem is still there after that.
