Track Noob tire question
Old May 22, 2004 | 11:43 PM
98cwitr's Avatar
98cwitr
Where's the DC5R???
Advans A032s<Toyo's?
Old May 23, 2004 | 05:42 AM
George Knighton's Avatar
George Knighton
A032R seem to last a long time. Longer than the Toyo. The only person I know who's driven both tyres on the track is Bryan, who had A032R on his car and Toyo RA-1 on my car.
He thinks the RA-1 are better. RA-1 last a long time for an R comp, but not as long as his A032R lasted.
I have also tried one set of Kumho R comps (the new kind, not Victoracers). They were fine while they lasted, but didn't last very long and (to me) did not appear to handle any better than the RA-1.
I have never had Hoosiers on my car.
Old May 23, 2004 | 07:07 AM
nsxtasy's Avatar
nsxtasy
Yes, according to the general consensus I found when I asked the same question in this topic a year ago.
Old May 31, 2004 | 08:44 PM
PY 01-0972's Avatar
PY 01-0972
Default george need your input on rims
do you think that an aftermarket rim such as the konig trouble in a 15x7 with the falken azenis in a 205 50 would be an improvement for the r or is the 15x6.5 stockers with the re010's be my best bet for a novice auto crosser?
I guess my concern is that the aftermarket rim will not have the proper offset.
Since the r is tuned to suit the car best in all areas. thanks!
Old May 31, 2004 | 08:47 PM
PY 01-0972's Avatar
PY 01-0972
Default rims and tires
I now have the stock rims with toyo proxies tpt and am told its an all season tire. I think they handle great so I am sure anything will be an improvement.
they were on the car when I bought it and are brand new. thanks again
Old Jun 2, 2004 | 04:16 PM
Chris N's Avatar
Chris N
No R compounds for N00bs.
If you get RA-1, and wad up your car, we told you so.
Honestly. Learn on street tires, they communicate MUCH better and are much safer.
Old Jun 2, 2004 | 09:02 PM
PY 01-0972's Avatar
PY 01-0972
Default auto cross tires
yes thanks I will use the toyos that were on the car when I bought it.
Old Jun 3, 2004 | 11:13 AM
CanadianR's Avatar
CanadianR
How much experience would you veteran track guys recommend having before moving up to R compounds? I've done 8 autocrosses and an HPDE so far, and will have about 15 or so autocrosses and 2 HPDE's by the end of this year. I'm running Azenis now, but they will be spent by the end of this season. I'm just trying to decide if i should go with RA-1's next year or get another set of Azenis. I will be doing probably 10-15 autocrosses and 2-3 HPDE's per year, and the tires will be mounted on Enkei ES Tarmacs, 15x7.5" front and 15x7" rear. ( not that that likely matters)
Old Jun 3, 2004 | 02:04 PM
nsxtasy's Avatar
nsxtasy
I don't think there's any specific, hard and fast number but I would guesstimate maybe a minimum of 10-12 HPDE events, and maybe more.
Old Jun 23, 2004 | 12:13 PM
autoXitrSoCal's Avatar
autoXitrSoCal
Thanks for the caution on tire choice for nOOb track days. I have close to 20 autox's and 4 autox "practice days" so I was figuring on just using R-compounds like in autox. In D-stock last year I ran RA-1's (F)225 & (R)205 but this year I have been running on (F)225 victoracers & on the rear I have the 225 RA-1's from last year) all on stock size rims. I do get slight evidence of rubbing, but never any grinding noises (note: use 5 mm spacers on front).
For going to the track, I was going to get a set of RA-1's to put on 15x7's (43 offset) but wasn't sure about all 205, all 225 or (F)225 & (R)205. But now I think I will just try the 205 azenis's I have on my 15x7 street setup for the first event. Later on when I go with R-s, what sizes do you recommend?
One other thing, the stock size rims are 15x6JJ 50 offset, it is stamped right on the 01 gunmetal's.
