plugs?
Old May 11, 2004 | 03:14 PM
TegraGSR's Avatar
TegraGSR
Default plugs?
I can't decide which spark plugs to buy. I've heard a general consent that Denso and NGK are the way to go, but which kind platinum, iridium, copper? Theirs all different kinds of Denso's and NGK's not just types of metal but two prong four prong V-power etc. Please help and dont ignore this thread!
Old May 11, 2004 | 03:44 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
I just use copper NGK "V-power"... just don't forget to change them every 10K miles.
Old May 11, 2004 | 05:36 PM
c_rogue69's Avatar
c_rogue69
wtf goes here?
I always heard 20K miles
Old May 11, 2004 | 07:45 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Assuming you stick with the stock NGK PFR6G-13 platinums the Helms manual says they should be changed every 60k miles or 48 months, whichever comes first.
I would stick with those or if you want a cheaper option that you can tell yourself performs a *tad* better, you can get the NGK copper plug of the same heat range as stock. Off hand I couldn't tell you the part number though.
Old May 11, 2004 | 08:19 PM
Epoch's Avatar
Epoch
I consider it good practice to use copper plugs. It makes me check them more often, and thus I have a pretty good idea how my engine's doing about twice a year or so
Old May 12, 2004 | 08:10 AM
TegraGSR's Avatar
TegraGSR
aight im gonna go with NGK Platinums since i got barely any feedback about my question. how do i kno if i need to regap my plugs? what is the standard gap for 95 GSR's. I have a few mods but will that matter? Also how do i asess damage done by bad plugs?
Old May 12, 2004 | 08:18 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The stock NGK PFR6G-13 platinums should be gapped from 1.0 to 1.1 mm (0.039 to 0.041 in) and then torqued down to 13 lb/ft.
What sort of damage was done by bad plugs?
Old May 12, 2004 | 11:28 AM
BuLLeTeG3's Avatar
BuLLeTeG3
I believe it should be gapped 0.051 in.
Old May 12, 2004 | 11:38 AM
TegraGSR's Avatar
TegraGSR
earlier i posted bout engine lag which turned out to be caused by a bad O2 sensor but i still misfire sometimes it seems, not quite as bad as before so therefore im checking my spark plugs to see if they've gone bad.
Old May 12, 2004 | 01:56 PM
TegraGSR's Avatar
TegraGSR
aight so i just took out my spark plugs and looked at em. my number 2 piston (2nd one from the right) has oil on it. not just a little its 2/3 coated in oil. how much trouble am i in? please help i fear the worst...
