94-01 Integra Front Bumpers...Question
I though this would be the forum to ask.
I think it's the 94-97 and 98-01 bumpers that differ correct?
Can you swap the newer style onto the older integ fronts without changing anything??
He means the 98 spec onto the 94-97. The 98 and up bumpber will go right on to the 94-97 tegs. Although, since the headlights were made to protrude a bit further in the 98 spec's, I think there will be a gap inbetween ure headlights and the 98 bumpber, unless you also get 98 spec headlights.
Here's how it works.
To swap a 98-01 front end onto a 94-97 Integra, you will need
The actual bumper (duh)
The matching Headlights (from a 98+)
The matching side marker/turn signal lamps (from a 98+)
The 94-97 Headlights won't fit through the ports in the newer bumper. Plus since the angle of the exterior lens was changed for 1998+, even if you manage to get the older HLs to fit, it will look damned strange. And for the turn signals, it should be perfectly obvious[once one studies the differences between the two bumpers] that the 94-97 units simply will not fit in any way.
And as far as the rear bumper goes, a coupe bumper will swap to another coupe - just as a sedan bumper will swap to another sedan. A coupe bumper can't be used on a sedan and vice versa.
Addicted2Racing
Vehicle Classifieds
13
Apr 28, 2004 06:42 AM
