Engine block JERKS while shifting from Park->Drive->Reverse
Old Mar 31, 2004 | 08:25 PM
MitzEclipse's Avatar
MitzEclipse
Default Engine block JERKS while shifting from Park->Drive->Reverse
Hi All,
I just noticed it when my friend was putting my car from park -> reverse -> drive and I had the hood open - the entire engine basically jerks while being shifted. Is this normal? Is something lose?
I have a 1995 Acura Integra Special Edition, Automatic.
Thank you
Old Mar 31, 2004 | 08:34 PM
ls_101's Avatar
ls_101
integra fs
they all do it, you can reduce it by putting poly mounts in but otherwise dont worry its normal
Old Apr 1, 2004 | 06:16 AM
pirate252's Avatar
pirate252
If it is exsessive it may be from one of your motor mounts being broken
Old Apr 1, 2004 | 06:55 AM
93Nteg's Avatar
93Nteg
Check the mounts.
Old Apr 1, 2004 | 07:26 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
https://www.honda-acura.net/forums/s...d.php?t=128656
Old Apr 1, 2004 | 11:33 AM
MitzEclipse
Thank you for the replies - my engine jerks almost like the ones in the video on the thread that MrFatbooty linked (thanks for that link)
No one came to the conclusion it was the engine mounts... is it? Anyone know? Is this normal or should I do something about it? I don't want anything to get worse...
Old Apr 1, 2004 | 01:09 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Basically the transmission shifting causes the drivetrain to torque at its mounts. Over time the mounts get worn down and offer less resistance to that torque. So yeah most likely it's the mounts are worn which is why you're noticing the drivetrain jerking around more.
Old Apr 1, 2004 | 03:21 PM
MitzEclipse
How hard is it to fix/change the mounts? Any idea how much the mounts cost? Do you need any special equipment or is it fairly easy to fix?
Thank you!
Old Apr 1, 2004 | 04:49 PM
Rice_Barn's Avatar
Rice_Barn
Auto Performance Shop
mounts are easy to fix. un bolt, pull, replace, bolt. cost, depends on where you get them from. the hard parts are; unbolting~how much road grime has accumulated? And linning up the engine/tran to re bolt. both easy to deal with, but heads up.
Old Apr 1, 2004 | 05:30 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
You also should support the drivetrain with a transmission jack or something similar while pulling the mounts.
Hans Stoner
Feb 4, 2004 10:23 AM
Nec
Accord
2
Sep 25, 2002 06:13 PM
myka7500
92+ Civic/EL & Del Sol
Sep 2, 2002 05:37 PM
myka7500
Sep 2, 2002 04:04 PM
jaje
News & Rumors Archives
Jul 11, 2002 08:01 AM
