Could fuel cutoff switch affect performance?
i recently installed a cutoff switch..i used 18 gauge wire and i believe 6amp rocker switch..i read that 18ga was okay but can someone confirm that? i believe i read somewhere it fried on someones car while driving at high speeds..also this past week i noticed after installing the switch the performance has gone down a bit..could it be that the wire is not big enough because as i step on the gas it doesnt react as quick.feels like it takes a sec before fuel gets to the engine..last quewstion is anyone know what wire to cut to disable power locks..thanks
Originally Posted by Epoch
Well, increased resistance could, I guess, cause that... how did you join the wires and the switch together? I hope you soldered it?
Resistance definitely would be an issue. I take it this cutoff switch was installed on the power wire for the fuel pump? If the pump is not receiving enough current it can indeed not perform like it's supposed to. 18 ga is some pretty scrawny wire.
Originally Posted by pirate252
Electrical signals travel at the speed of light, even if it did have some resitance, you would never notice a lag...
BTW, your Integra is a DC, I take it? Just curious.
The wire seems too small, I'd go to 14 gauge. Also, instead of a direct switch, I'd use a relay to switch the current to the fuel pump. It should be fairly simple to mount the relay under the center console bin :dunno:
Relays work great for starter kills, but are less convenient for fuel cutoffs.
But what would be a good thing to hook the relay up to? It's gotta be something you want on when you're driving the car, but a thief wouldn't turn on.
I'll come back to discuss this a bit more clearly in a bit, hopefully.
h:
