Could fuel cutoff switch affect performance?
Old Mar 31, 2004 | 05:13 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
Originally Posted by NorCal DC4
I was considering the option of installing a relay as a more secure means of switching a high amperage circuit w minimal resistance. The relay would be controlled by a low voltage circuit added to the car, with the switch controlling the relay hidden inside some storage compartment or under a false panel.
I'll come back to discuss this a bit more clearly in a bit, hopefully.h:
I see... use the relay to manage the fuel pump, and have a switch controlling the relay hidden... I shoulda done that h:
Old Mar 31, 2004 | 05:14 PM
qtiger's Avatar
qtiger
I would put the switch on the ground, not power.
Old Apr 2, 2004 | 06:16 AM
pomansouth's Avatar
pomansouth
best point of the whole day, put it on the ground side of the loop instead of the power side.
Old Apr 2, 2004 | 06:22 AM
Kai's Avatar
Kai
Rotorphile.
18ga? My hair is thicker then that. :chuckles:
I would have used at least 14ga for the job, 12 or 10 would be even better. It is the fuel pump afterall, bad things happen when it doesn't work.
The easy way to test if it's bad is to just jump the wire you spliced into back together. I've made jumper wires my self for reasons like this.
xbladr
Engine Swaps, Tech & Tuning
4
Jan 17, 2003 07:00 PM
Quick Silver
5
Jan 15, 2003 01:32 PM
jaje
News & Rumors Archives
12
Dec 26, 2002 08:41 PM
RST531
92+ Civic/EL & Del Sol
6
Nov 14, 2002 04:28 PM
slowcrx
CRX & Pre 92 Civic
5
Aug 26, 2002 06:10 PM
