Eating Oil????
Old Jan 14, 2004 | 08:15 AM
Jan Niemi's Avatar
Jan Niemi
Originally Posted by 98cwitr
before i installed the header though i never burned a drop, nor did my oil ever get dark...now its a different story, i guess thats what you pay for performance :?
The only way a header could affect your oil consumption is if the added heat burned the o-ring in your dipstick tube. Once the crankcase pressurizes, it will vent through the path of least resistance, which in your case may be the dipstick tube. It will be relatively unnoticeable because it will vent as a fine mist, which you will hardly notice except for the smell of it burning off the header.
Just an idea....
Old Jan 15, 2004 | 09:21 AM
98cwitr's Avatar
98cwitr
Where's the DC5R???
check your TB for oil...it could be coming from the valve cover, oil catch can would come in handy
Old Jan 16, 2004 | 05:24 PM
TypeR178's Avatar
TypeR178
I dont want to be the bearer of bad news but i had the same situation with my R. I had always used synthetic oil and i take good care of her, hell i dont even drive that hard very often. So was stumped as you seem to be, i did a compression test and they were within spec so to make a long story short i had a burnt valve on the number 3 and stuck top rings on the same cylinder. But no visible soot or any of the normal tell tale signs.
As for the validity of this full synthetic oil burning more frequently can anybody offer anything concrete?
