Experimenting
Old Sep 3, 2003 | 08:32 AM
Jan Niemi's Avatar
Jan Niemi
Well I'm playing around with fuel pressures again. I'm running less than 40 psi all the way across the rpm range. Still using the VAFC, but now I had to install check valves between the map and intake to make sure the ECU sees 0 boost, since I am using less than -38 fuel settings on the VAFC, it is no longer tricking the ECU into not seeing boost. So far the results are excellent, I may still go to the strip this year with this setup, because by this spring it will be Hondata and no more VAFC games.
Old Sep 3, 2003 | 10:54 AM
ITR41's Avatar
ITR41
just be careful on that set up. if you run a missing link on the map it will make the car run really lean unless you have a FMU. just listen very close for knock and good luck
Old Sep 3, 2003 | 11:21 PM
Erik B's Avatar
Erik B
I got something for you Jan...Nov... :lol: I'll let you know...Anyone looking to buy a FMU, VAFC and a In Line fuel pump :lol:
Old Sep 4, 2003 | 02:42 AM
Jan Niemi's Avatar
Jan Niemi
Good man! I want all the details
Old Sep 4, 2003 | 06:07 PM
integracer800's Avatar
integracer800
Yo,
Jan Niemi could you post those sound clips again, the other ones wont work 4 me.
Thanks
Old Sep 5, 2003 | 02:44 AM
Jan Niemi's Avatar
Jan Niemi
Originally Posted by integracer800
Yo,
Thanks
Something's f****d up at WTDR, so I will have to find out what. Or I'll have to host it on my personal website, I'll have that up soon, when I do, I'll post the URL
Old Sep 5, 2003 | 08:21 AM
Jan Niemi's Avatar
Jan Niemi
update:
VAFC throttle points set at 10% lo 50%hi. VTEC at 5000. Idle -50%, -38% up to 3000 on low cam low throttle, hi cam hi throttle +15 at 4500 up to +25 at 8500. So far I've only dared to rev to 7000 (trying to keep EGTs below 1450). It runs beatifully from idle to 7000 spinning the tires as soon as she sees boost and VTEC. I'll play around some more and update more later.
This is with fuel pressure at 37 to 38 at idle, dropping to about 27-30 at WOT. (modified stock reg - not what you think either) I know it's contrary to FMU type mentality, but interesting. I might hook up the FMU this weekend (maybe)
Old Sep 5, 2003 | 12:21 PM
ITR41's Avatar
ITR41
with you adding fuel like that you are probably OK
