wheel hop
Old Jan 29, 2003 | 01:48 PM
bbqman's Avatar
bbqman
Originally Posted by Kangbateh
under hard acceleration how do you eliminate wheel hop?
Stickier tires.........
Old Jan 29, 2003 | 02:27 PM
Kangbateh's Avatar
Kangbateh
Okay, here's the tough question. What type of tires would you consider using? Man, there's a shit load of tire's out there I wouldn't even know where to start. :twisted:
Old Jan 30, 2003 | 04:19 AM
bbqman's Avatar
bbqman
See my post on the tire thread..previously.
In any case, for a reasonable amout of $$$ , TOYO RA-1 will eliminate lotsa wheelspin associated with non-R- compound tires. But as also previously stated......considerable wear........but who cares about wear when it hooks up!
Old Feb 1, 2003 | 08:52 PM
Jan Niemi's Avatar
Jan Niemi
I installed my z10 today, unfortunately it interferes with my Moroso oil pan, I will probably have to fab up some new brackets for the radius arm to change the angle. Give me your e-mail address if you want me to send you pics.
Old Mar 19, 2003 | 08:22 AM
Jan Niemi's Avatar
Jan Niemi
Finally it's March and I'm driving the teg again. The Z10 setup is fantastic. The launch is so damn hard, it's hard to believe. I need to adjust the preload still, the car pulls to one side a little bit. There is also a slight interference issue with the left rod touching my Moroso oil pan under certain conditions. Contrary to what I said in previous posts, I may put urethane engine mounts on this car, even though they are very harsh. This might eliminate some of the contact the rod is making with the oil pan, or I might machine a recess into the rod, I will post whatever I end up doing.
Old Mar 19, 2003 | 11:32 AM
Erik B's Avatar
Erik B
Jan, What did it do to you 60 foot times?
Old Mar 19, 2003 | 03:10 PM
Kangbateh's Avatar
Kangbateh
What are Z10's ? :twisted:
Old Mar 20, 2003 | 02:43 AM
Jan Niemi's Avatar
Jan Niemi
Eric, I haven't been to the track yet, Kang, check out Z10 engineering web site...
Old Mar 20, 2003 | 02:56 PM
Kangbateh's Avatar
Kangbateh
I'm guessing it's www.z10.com :twisted:
Old Mar 20, 2003 | 03:43 PM
Jan Niemi's Avatar
Jan Niemi
Kang it's http://www.z10eng.com/
