integra CV joints
Old Mar 27, 2004 | 05:14 AM
brentom2's Avatar
brentom2
Default integra CV joints
how hard is it to change these? it looks extremely difficult and messy . I am really having a tough time what I Need is A really good pep talk from someone who has performed this Job and knows the best way to do it
Old Mar 27, 2004 | 05:18 AM
Daniel's Avatar
Daniel
You can do it, as long as you have the correct tools! We'll help along the way if you have problems...
My brief walkthrough: https://www.honda-acura.net/forums/s...d.php?t=129362
agileauto.com's Avatar
agileauto.com
I h ave rebuilt about 500 axles in my time. what's the problem? how can I help?
Old Mar 27, 2004 | 05:34 AM
brentom2's Avatar
brentom2
I think I have all the right tools and can get Remanufacted axles for 69$ apeice. How long should this job take?
Old Mar 27, 2004 | 05:38 AM
agileauto.com
your first time, you can plan on about 1 hour per axle.
Old Mar 27, 2004 | 06:00 AM
brentom2's Avatar
brentom2
thats not bad first caliper then 32 mm nut then lower control thenwhat?
Old Mar 27, 2004 | 01:34 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Here's the section from my Helms manual on the driveshafts. It's a '93 manual so if you have a '94-'01 car not everything might be the same but it should give you a good general idea.
File Type: pdf
Old Mar 29, 2004 | 05:06 AM
agileauto.com
break the ball joint loose(17mm), then remove the hub from the lower arm. then take off the 32mm axle nut, then pop the axle out of the trans carefully using a screwdriver or prybar, then take off the wishbone mount(17mm) on the lower part of the strut, then take it off at the strut(14mm). break that loose, slide the trut out of the way to take off the wishbone, then you're home free.
Old Mar 30, 2004 | 06:32 PM
brentom2's Avatar
brentom2
Default thank you all
thank's for all the help this is going to be fun now that I know what I am doing. the hard part now is trying to convince my wife to let me spend some money on car parts. she always says we don't have any money last time i checked we had all kinds of money. well you know how wives and sports cars get along.
Old Mar 30, 2004 | 07:46 PM
LT's Avatar
LT
The deer had to die!
the hardest part about working on your axles...is getting them back in by yourself. if you are doing it by yourself, you'll see what i'm talking about.
