Power Steering Help!!!(Mechanics only)
aiight can someone help a lady out again...my power steering pump, i thought, went bad on me, but it was'nt that, it was the tube running down into the pump from the fill container ,the tube was being sucked in when i turned on the car, my brother and i thought it was the pump soo i spent a bill on that and a new aluminum pully, that did'nt change anything, question?? Could it be the Power Steering Rack?? do i need to replace that?? is there a power steering switch that went bad, i don't know what the problem is?? can any of you mechanics help me out!! i did remove the PWS belt so it won't continue to pinch, kinda made the car somewhat faster , less pull on the engin, butt its a ***** reverse and turning, all in all i kinda like it without the belt, well can anyone help??
thankz
thankz
no leaks everythings snug tight, hose looks fine no cracks on hose,still tight,its not soft, any other suggestions??how bout the switch on the pressure hose, whats that for??could the reservoir be clogged??should i run a air pressure to clean it out to unclogged it??
HELP!!
HELP!!
alright, does anyone have any other ideas on what the problem is?? even tho i like the fact i dont have Power Steering and it makes the car a bit faster and more pick up, i still need to fix the damn problem
!!help me out MECHANICS??
gen
!!help me out MECHANICS??gen
O.k. here's your answer
From your description, the hose that connects the reservoir (gray with red cap) to the power steering pump is being "sucked" closed. Right?
This hose is not under any pressure, fluid is gravity fed to the power steering pump. One of two things is wrong.
1) The inlet tube (the one sucked flat) is old and needs to be replaced
2) There is some sort of obstruction in the bottom of the reservoir.
Either way, this is what I would do:
Drain the fluid from the reservoir, all you should have to do is remove the inlet tube and fluid should come flowing out. Replace this hose with one from the factory, it's probably around 20-30 bucks which sounds expensive when it comes to a hose, but compared to a new pump and rack, that's nothing.
Next remove the power steering reservoir from the mount and flush it with some sort of solvent. I usually use paint thinner, seems to work pretty well. Plug up the ends and shake it around for a while. Rinse it out with water. Fill it with water and hold it in the same orientation as it is in the car. Water should gush out of the outlet tube. If it doesn't you should either look harder at getting the obstruction out or get a new reservoir.
Good luck, this should fix your problem.
BTW, Power steering is a self bleeding system, the only thing you have to do is essentially use it... turn the wheel lock to lock a couple of time and no more air as long as the entire system is in good shape. This is because the fluid is fed by gravity to the pump inlet, then compressed and routed to one side of the hydraulic ram (power steering rack) while the other side bleeds it fluid back into the PS reservoir. Pretty neat system really!
ramtz76
Do It Yourself
7
Aug 15, 2009 07:14 PM
Katana950
5
Oct 4, 2004 04:24 AM
krnbk2
92+ Civic/EL & Del Sol
3
Sep 7, 2002 11:07 AM
