Humming noise at high speeds
Old Mar 7, 2004 | 01:42 PM
94acura's Avatar
94acura
Default Humming noise at high speeds
I have a loud humming noise at 40 mph and above. It doesnt seem to be coming from the engine compartment but rather the rear wheels or axle. Also there is an inordinate amount of black stuff on one of my rear wheels, there is road construction down the street and I assumed that it was just tar but now am unsure. Can anyone help?
Old Mar 7, 2004 | 02:10 PM
steve 97tl's Avatar
steve 97tl
It seems that your rear tires could be cupped causing a humming noise.Try running your hands up and down the tread and see if you have high and low spots also a flat spot would cause this too. Also the hub and bearing if they go bad will produce the same noise which is evident more with speed. Hope this helps you out Steve 97tl
Old Mar 25, 2004 | 03:55 AM
bigt61's Avatar
bigt61
check your tire balancing.. if its out, it will hum. does it feel like the wheel is shimmying?
Old Mar 25, 2004 | 06:30 AM
newgsrdriver's Avatar
newgsrdriver
Have you tried to pinpoint it to a corner?
Does it sound like a groan?
Could very well be a wheel bearing...the rears tend to go pretty often.
Old Mar 25, 2004 | 07:51 AM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Nick beat me to it: most likely a wheel bearing problem.
Old Mar 25, 2004 | 08:01 AM
Singhg83's Avatar
Singhg83
BALLIN'
i had the same problem. i got new wheel bearings and problem solved. it usually got loud around 40mph so that could be a possibilty
Old May 12, 2004 | 03:39 PM
Mark dlR's Avatar
Mark dlR
Hello. I just picked up a '94 GSR. I noticed this type of problem as well, but for me, it would happen starting at around 20-25, and I would hear it in the front rather than the rear. Then, it would get higher pitched as I'd pick up speed. But then, it goes away on the freeway when my foot's on the gas and come back when I release the gas (to brake or exit). Does this sound like the wheel bearing as well? That was my first guess, but I wanted to ask others first.
BTW, this is my first post here and my first Honda/Acura. I avoided them before because they're mostly FWD--started out driving a '91 Corolla then got a '95 525i. Loved the Bimmer, but my aunt was selling the Teg. Bone stock, driven casually (until now!), 84K miles for 5K. She kept the inside real clean too. I never listened when my friends would talk about the car ... German car arrogance, I guess. But, I'm amazed at what it can do. It's torqueyer then I thought. I entered the freeway here in 2nd gear. I'm still trying to take that car up to redline, but I hit 70 in 2nd gear! The double wishbone's awesome. I'm taking her to her first auto-x this Saturday. Any tips? I'm thinking of not modding it out until I learn her limits with stock components ... but I'm getting really tempted.
Mark dlR
Old May 12, 2004 | 06:37 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
The way you describe it sounds like a wheel bearing to me.
Congrats on the purchase. I'd recommend a set of sticky tires as your first "mod."
Old May 14, 2004 | 09:33 AM
Mark dlR's Avatar
Mark dlR
Thanks! Yeah, the tires it came with are pretty decent. Toyo Proxes F4Z. She just replaced them not too long ago. When the time comes--after a few more autocrosses and possibly a track day--I'll either get some Kumho Ecstas or Falken Azenis, Bridgestones if I decide to splurge. Before then, I was thinking of some coilovers and sway bars. I saw pics of Integras in auto-x. There was quite a bit more roll than I would like.
kfar09
3
Jul 24, 2003 07:58 AM
FoB616
16
Jul 23, 2003 11:27 AM
ninety4
Accord
5
Jul 1, 2003 02:59 AM
VTECNLUDE
Prelude
6
Oct 16, 2002 02:12 AM
KKTPP
54
Jul 11, 2002 12:05 PM
