Front sway bar?
Old Feb 17, 2004 | 06:29 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
You don't really want to go to a thicker sway bar up front. The whole point of going with a thicker rear bar is to bring the balance of the car away from understeer and increasing the roll stiffness in front encourages more understeer.
Oh btw, the '98-up JDM ITR did come with a 25 mm front bar. The '99-'00 Si coupe does have a rear sway bar as well, not sure if it's the same 19 mm as the Integra or something thinner like the Civic EX.
Regardless, the stock GSR front sway bar is the way to go.
Old Feb 17, 2004 | 06:41 PM
ISP James's Avatar
ISP James
DAMIMRED
19mm rear? 13 for LS, 14 for GS-R and 22 for ITR is what i was told...
Old Feb 17, 2004 | 06:45 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Yeah you're right, I was thinking 4 and hit the 9 key. :doh:
Old Feb 17, 2004 | 06:57 PM
ISP James's Avatar
ISP James
DAMIMRED
phew, i was afraid that all this time i had been misinforming people
Old Feb 18, 2004 | 10:08 PM
Spec R's Avatar
Spec R
the 96 ITR's had 24mm front sway bars and the 98-01's had 25mm. USDM 00-01 Integra LS/GS have 24mm sway bars. just letting u know
DB Squad
Integra Forum Moderator
Old Feb 18, 2004 | 10:58 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Sorry, I just checked the part numbers and they are identical for '97 and '01 ITR front sway bars.
Only the '98-up JDM ITR has a different front bar.
Old Feb 19, 2004 | 04:03 AM
Asahi's Avatar
Asahi
Administrator
I've never heard that the Swaybar for JDM models changed and don't see any reason to think it did based on speculation. The JDM REAR swaybar is 1mm larger but there has never been any discussion about a larger front swaybar.
The 97-01 USDM ITR FRONT Swaybar is 0.94" according to the brochure which is 24mm (Actually slightly less)
Old Feb 19, 2004 | 04:23 AM
stockhonda's Avatar
stockhonda
will a ITR rear sway bar bolt right onto a 98 LS?
Old Feb 19, 2004 | 05:40 AM
Asahi's Avatar
Asahi
Administrator
It won't bolt right onto and you will need to consider subframe reinforcement to prevent severe camage to the subframe.
I'd suggest looking here: http://www.beaksproducts.com/main.html
Note: The reinforcement kits to NOT gurantee tthat the subframe wwistand up to the forces subjected to it by a larger swaybar.
Old Feb 19, 2004 | 08:38 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Yeah, the USDM ITR has 24/22 mm sways front/rear. I was under the impression that when the '98 JDM ITR got the 23 mm rear sway bar its front bar grew to 25 mm to keep the overall balance front-to-rear about the same, but I can't remember where exactly I got that info.
For all intents and purposes though, we can just say that for an Integra the best thing to do is stick with a 24 mm front bar.
MrChad
Accord
11
Aug 15, 2003 06:07 PM
ManTiS
92+ Civic/EL & Del Sol
56
Jul 3, 2003 12:55 AM
jordan88
9
Dec 12, 2002 08:02 AM
teaminspire
Sep 15, 2002 11:42 PM
