Front sway bar?
Torsional stiffness goes with dia^4, so 25mm would be almost 18% stiffer than 24mmm. But I think the bar doesn't go straight side-to-side, so it's not exactly that simple.
Still, the rear bar is LOTS stiffer.
Originally Posted by Asahi
ITR Front Swayber is the same diameter as the GSR front. The place there is a significant difference is the 14mm GSR rear swayber vs the 22mm ITR Rear swayber.
And get the Comptech Rear Tie/Sway if you are doing anything back there :goodjob:.
99 Integra GSR
06 TSX
duck squad member #00003
99 Integra GSR
06 TSX
The civic SI has a 26mm front swaybar...but you need SI LCA's to use it.
h:
h:
