b18?b20
Old Dec 15, 2003 | 02:43 PM
ISP James's Avatar
ISP James
DAMIMRED
Originally posted by RB
get a b20 block, mate it with a b16 head w/ some ctr pistons and crower 404's, then you're all set.
no, b16b (ctr) pistons are 81.5mm b20 pistons are 84....
go with b20 + turbo, more reliable and less headache to piece it together.
Old Dec 15, 2003 | 05:25 PM
aphex's Avatar
aphex
driftin'
Yeah but the headache comes back 6 months later when you have a blown motor
If you go b20 turbo you better make sure you do it flawlessly, and make sure the sleeves are set... otherwise your only gonna get 500 miles out of it
Old Dec 15, 2003 | 06:04 PM
Snoopy's Avatar
Snoopy
been there done that
ctr pistons come in stock 81mm and overbore of .25mm
Old Dec 16, 2003 | 01:12 PM
DB7 2.0's Avatar
DB7 2.0
Banned
i had both a cam'd B18B and now a JDM B20B. the B20 > cam'd B18B.
Old Dec 16, 2003 | 03:25 PM
ISP James's Avatar
ISP James
DAMIMRED
im strongly considering a b20 instead of rebuilding my b18b... well id be rebuilding the b20, too.... the 133 ft/lbs is a turn on
Old Dec 16, 2003 | 03:27 PM
ISP James's Avatar
ISP James
DAMIMRED
posted twice, you can delete this if you want to... h-a.net is giving me hell tonite
Old Dec 19, 2003 | 01:14 PM
york2600's Avatar
york2600
Bit of advice. If you wanna do a B20/VTEC right it's damn expensive. I got into the project and didn't realize how much it was going to cost to do it right. You don't want to drop a few grand into an engine to have it blow up, but in order to make last you have to drop a few grand more into it.
Engine:
- JDM B20(z) Block bored .4 over
- Balanced crank
- USDM B18c1 Head
- Pocket port
- All gaskets replaced with OEM Honda gaskets during build-up
- JE Pistons (Approximately 11:1 compression)
- Eagle H Beam Rods w/ ARP Rod Bolts
- Block Guard
- ARP head studs
- STR valve seal
- Oil line kit
- Unorthodox Racing lightened crank pulley
- Unorthodox Racing lightened power steering pulley
- Skunk2 Intake Manifold
- STR throttle body
- AEM Cold Air Intake (Type R Size)
- AEM Fuel Rail
- AEM Fuel pressure regulator
- RC engineering 280cc injectors
- DC Sports stainless steel 4-2-1 header
- Greddy Evo cat-back exhaust
- Denso Iridium spark plugs
- Magnacor spark plug wire
Old Dec 19, 2003 | 09:44 PM
Shore 96 Teg's Avatar
Shore 96 Teg
I miss my 93 VTEC Lude :(
wouldnt the b16 head out of a Civic Si and a CRV B20 match up no problem? they are both VTEC motors....cept the civic is DOHC VTECand the CRV is iVTEC
Old Dec 19, 2003 | 09:55 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
Nope the b20's are not vtec
Old Dec 19, 2003 | 10:06 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
B20 doesn't have iVTEC :eh:
