b18c1 NA
Old Nov 26, 2003 | 06:45 AM
narib_16's Avatar
narib_16
Keep It Nice, Not Rice!!!
Originally posted by CiViC2nR86
You dont want to put a b16 head on your b18. If you are just trying to achieve numbers, sticky tires will not help. Why would you want to make it "like" a type R when you can make it beat a Type R??
i believe a type R make around 165 to the wheels stock while a gsr is around 150, Just through i/h/e/c i should be able to come close in a race,Itr is also 100 pounds lighter and better suspencion and lsd.
How would i go about porting stock intake manifold and throttle body?You think thats gonna be better than buying say skunk2?
Also is 12:1 too much?Am i gonna shoot a piston through the roof, or something?
Old Nov 26, 2003 | 10:46 AM
dustimus's Avatar
dustimus
Better golfer than you
12.1 is not too high but you will have to drive aroudn with at least 93 octane and even run with octane boost to prevent detonation until you get it tuned with some fuel management such as hondata
Old Nov 26, 2003 | 06:19 PM
Snoopy's Avatar
Snoopy
been there done that
hoping to run with an itr with only i/h/e/c is not going to be easy. send the i/m and tb out to a shop that knows what its doing. a skunk2 i/m will give you better gains in the top end put you'll lose some in the bottom end.
Old Nov 26, 2003 | 06:33 PM
dom93hatch's Avatar
dom93hatch
more meat, more fire
Have the correct fuel setup and you should be fine on 93 octane.
Old Nov 26, 2003 | 09:36 PM
CiViC2nR86's Avatar
CiViC2nR86
JDM Padawin
Snoopy, when u gettin ur car man?
I hope you have the money to do what you like to the car man, I'd really like to see the outcome
Old Nov 26, 2003 | 09:48 PM
Snoopy's Avatar
Snoopy
as would i h: :sad:
Old Nov 26, 2003 | 10:00 PM
91Teg's Avatar
91Teg
4-1 header=15-25HP maybe?
AHAHAHAHAHAHHAHAAHHAAHHAHAHAHAHAHAHAHAHAHAHAHAHAHA HAAHAHAHAH. AHAHAHAHAHAHAHAHAAHAHAH. Alright no really AHAHAHAHAHAHAHAAH. Man you are to much.
Old Nov 26, 2003 | 10:01 PM
Snoopy's Avatar
Snoopy
with an off the shelf mass produced type like dc, dreaming. but with the high end hand built headers, possible.
Old Nov 26, 2003 | 11:19 PM
CiViC2nR86's Avatar
CiViC2nR86
JDM Padawin
Fool, did you even check all the link I posted up top? I am basing my estimates on the test result on this site. http://bob123e.tripod.com/thegreatheadertest/
Laugh all you want but that ITR is putting out 176 to the wheels, and the best header they've tested got it to put out 190 to the wheels. From 176-190 is 14 hp. Pretty close . There are other header, such as custom engineered or drag header that could add more than that. Also since you quoted me correctly, you should be able to read that I put "maybe?" at the end of that statement.
Old Nov 27, 2003 | 03:42 AM
pomansouth's Avatar
pomansouth
the reason why he is laughing histerically is because your common dc or of that sort might get 3whp with intake and exhaust.
