Help - 92 Integra LS starting problems............
Originally Posted by jdmnorcal
I have a 92 LS teg that all the sudden died today. I was able to start it up but it would shake like crazy, sputter, and eventually die. Even if I had the pedal to the floor it would onlly rev to about 1200 rmps before it would die. I assume it is the fuel pump or a relaly because it was driving fine earlier. I recently had the belt changed. Sometimes at higher rpms I would notice the rpms jump around a bit because of the bearings in the distributor are a bit worked. Where should I start? Has anyone had this same problem?
i have the same problem with my car, except that when i leave it in the sun for a few minutes it some how looses fuel pressure and it turns off right after its starts, and it wont turn on until i leave it alone for like 5 min, i dont know what the problem could be, i took it to speedee and they told me it might be the fuel pump, so i got that replaced and it still did it, if anyone had this problem please help. someone told me it could be the main relay but i checked it and it didn't smell burnt.
