Engine Swap Or Conversion
Old Nov 8, 2003 | 11:19 AM
sick79's Avatar
sick79
Originally posted by Kai
Well, we sould really say you don't need mounts for a DA9 Integra. The first gens, the DA3, does require mounts.
your right, i forgot those first gen tegs are da's too.:thumbup:
Old Nov 8, 2003 | 11:28 AM
reno96teg's Avatar
Originally posted by NXR03
my bad this is my work pc and it always on caps lock and i forgot, wont happen again.
:bs: you can see what you're typing. don't do it again.
Old Nov 8, 2003 | 02:57 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
Anyway, you don't need a mount kit to put a B-series motor into a '90-'93 Integra. It will bolt right in.
If you're trying to do this on the *relatively* cheap side of things then I would go with a full B16 swap. You can run the B16 with the stock transmission but the gears will be a bad match for the powerband. You need the ECU and a few other things as well.
You could slap a B16 head on your B18A block but once again, the gearing will be badly matched to the powertrain and I'm personally not much of a fan of taking the stock B18A bottom end up to a VTEC redline without any reinforcement.
Old Nov 8, 2003 | 03:50 PM
JohnQPhats's Avatar
JohnQPhats
LS Master
Default Re: Engine Swap Or Conversion
i have a 90 ls and i want to know what would be better to do a j spec b16 swap or put the b16 top half on my bottum end. what would be the pros and cons of both. if i did the conversion what would i need to complete it from the doner.
I would just go ahead and do the swap. While a frankentseined motor would be awsome, you'll run in to some reliability issues. And you will warp your block. The LS just isn't ment to do that.
Old Nov 8, 2003 | 03:55 PM
StealthGPDB8's Avatar
StealthGPDB8
B16 swap is the better way to go. More reliable, and believe
me it's a fun motor. Just please use a J1, or S1 tranny with
that motor.
Old Nov 8, 2003 | 04:00 PM
Unklejman's Avatar
Unklejman
Skidmarks in the driveway
Is it really that big of a deal?
Old Nov 8, 2003 | 04:10 PM
Snoopy's Avatar
Snoopy
been there done that
yes
Old Nov 8, 2003 | 04:11 PM
Unklejman's Avatar
Unklejman
whatever
Old Nov 10, 2003 | 07:15 AM
NXR03's Avatar
NXR03
i can get the motor, tranny, ecu, and harness for about 1400 dollars i think thats the way i am going to go.
Old Nov 10, 2003 | 06:04 PM
Snoopy's Avatar
Snoopy
a legit motor? :eh:
