Engine Swap Or Conversion
i have a 90 ls and i want to know what would be better to do a j spec b16 swap or put the b16 top half on my bottum end. what would be the pros and cons of both. if i did the conversion what would i need to complete it from the doner.
:squint: You might want to turn off your Caps Lock first. :squint:
Originally posted by NXR03
sorry about the caps. do i need the tranny and a mount kit for the swap. i am kinda new to this. where should i buy the motor, not to expensive though
www.inlinefour.com is also a good company to check out for motors and transmissions.
www.hondaswap.com has a very detailed database on conversion info.
Also, I'd recommend Mike Kojima's excellent book...
Honda / Acura Engine Performance, by Mike Kojima. PenguinPutnam, 2002.
ISBN: 1-5578-8384-X
Kojima is one of the best technical writers alive. His book covers every possible motor setup, including hybrids, NA & FI, Nitrous, literally everything. And the info is presented in a truly understandable format.
ANYONE IN BALTIMORE AREA WHO HAS DONE SOMETHING LIKE THIS BEFORE
Originally posted by NorCal DC4
Place Racing & HASport make mount kits as needed for the swap you wish to make into your DA Integra.
ISBN: 1-5578-8384-X
ISBN: 1-5578-8384-X
Originally posted by sick79
you dont need to buy mounts to drop a b16 into a da integra.
