Engine rebuild...
Old Nov 3, 2003 | 05:15 PM
jinx-mitchell's Avatar
jinx-mitchell
The Comic Guy
Default Engine rebuild...
My 95 GSR has about 160K miles on it and it's time to be rebuilt. I want to use all Honda parts except for maybe some bolt on's or something. What do you guys suggest? I've heard that if i use an ITR exhaust cam with a CTR intake cam I will get a bit of extra power. Any truth to this? Also, I'd like to increase compression. What are the highest compression pistons Honda made for this engine? Anything else I should replace while I'm in there? I'm going to replace: cams, pistons and rings, t-belt, w-pump and gaskets... Oil pump? which gaskets do I need to collect? Thinking about getting cam gears (which one's) and pulleys (unorthadox good?) Thanks for any help guys...
Old Nov 3, 2003 | 05:20 PM
Snoopy's Avatar
Snoopy
been there done that
if you want to get new internals, itr cams and ctr pistons are a good upgrade. while you're in there, new itr valvesprings and intake valves wouldnt hurt.
Old Nov 3, 2003 | 05:22 PM
jinx-mitchell
The Comic Guy
I read that ITR pistons are 11.1 compression while CTRs are 10.8. Are you sure CTR's would be better? also, is there any truth to that whole CTR/ITR cam combo? Thanks
Old Nov 3, 2003 | 05:26 PM
Snoopy's Avatar
Snoopy
jdm itr pistons will give about 11:1 and ctr will give about 12:1. 00-01 itr and ctr cams are the same thing. 97-98 itr cams had 3 degrees less duration than ctr's.
Old Nov 3, 2003 | 05:38 PM
jinx-mitchell
The Comic Guy
JDM and USDM the same?
Old Nov 3, 2003 | 05:39 PM
Snoopy's Avatar
Snoopy
:yes:
Old Nov 3, 2003 | 06:27 PM
jinx-mitchell
The Comic Guy
Okay, so here's my list of junk...
Cams, Pistons, P-Rings, TB gasket, T-Belt, W-Pump, Belt tensioner, (Gaskets...) intake manifold, exhaust manifold, cylinder head gasket, valve cover gasket, cam seals, valve seals, valve cover seals and grommets, injector seat o-rings, Oil pan gasket, Oil pickup unit gasket, Waterpump gasket, Main crank seal, various bottom-end o-rings (end gaskets), AEM pulleys, AEM cam gears, OEM spark plugs, Cap and Rotor, & Plug Wires...
Let me know what you guys think. What about an oil pump? Do they die easily? I need input before I go and spend this much $$$ please. I'm pretty ignorant, but haven't ever taken any of my vehicles to a shop and like to do my own work. I learn something new everytime! :thumbup:
The gasket list was compiled from www.inlinefour.com
Old Nov 4, 2003 | 08:46 AM
jinx-mitchell
The Comic Guy
Bump.
