Tune Ups
If you don't put the parking brake on regularly, the caliper or cable can stick. They probably should have adjusted the valves too, check to see if they charged you for a valve cover gasket
they did check the valves....and i'm not sure about the prior owner, but i have never ever left my car without the parking brake on.
you have 7.5k, 15k, and 30k check ups i believe. the 7.5 is oil and oil filter. the 15k is oil again and other stuff like tranny fluid should be checked, brake fluid, wind shield washer fluid, brake thickness, power steering fluid. it is basically all of your fluids but i add a valve check in there as well. and the 30k is the 15k plus like check belts or something. the 90k is for the water pump and timing belt i believe.
